Lightbulb Creeky Gear Stick !
My gearstick has started to make a funny creeking noise when i go to shift a gear is this normal or is a drop of oil needed some where
Thanks JG911
Old 05-06-2008, 10:14 AM
Fast Corners's Avatar
What model of 911 is it. There are many different shifters that were put into the cars over the years. I would not go the oil route...it is too thin to provide long lasting lubrication. First thing I would do is check the bushings in the system to see if they are intact or excessivily worn. If they are ok disassemeble the shift linkage and use a good synthetic greese on all of the bushings and pivot points.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 05-06-2008, 10:29 AM
The Puff.
Mr.Puff's Avatar
White lithium grease is what I used when I put new bushings in. Works great. You can find the stuff anywhere.
Old 05-06-2008, 10:37 AM
Iv got a 1984 915 box goes in all the gears perfect,just creeks a bit.
Thanks JG911
Old 05-06-2008, 03:01 PM
While moisture isn't usually plentiful around the shift housing, I've seen my share of corroded shift housings. White lithium grease is okay but isn't waterproof. Instead, I'd suggest a waterproof synthetic grease.
The creaking noise could also be an imminent sign the shift lever is about to depart. The lower part is epoxied onto the upper part. After 20+ years, the glue says adios and the upper lever/shift knob assy. parts company with the part that can't leave.
Sherwood
Old 05-06-2008, 03:43 PM
Well iv got the mot this Friday morning so hopeing to sail through,then ill start looking into the shifter.
Thanks JG911
Old 05-07-2008, 12:21 AM
