-   -   Electrical help needed. (http://forums.pelicanparts.com/porsche-911-technical-forum/407795-electrical-help-needed.html)
HarriTiidus 05-06-2008 01:37 AM
im installing electrics in my car, in the steering column, flasher, light and so on wires.
there are 2 wires, brown with with stripe, which i have'nt found a place.
Any ideas where they go?
And if i dont have oil pressure sender connected ,does the gauge read max numbers.
thank you
OldTee 05-06-2008 04:29 AM
What year car.
Do you haves a Bently for your car. Schematics in back.
Oil Pres goes to max if wire disconnected at sender or sender bad.
HarriTiidus 05-06-2008 07:56 AM
i have haynes, but there it shows that brown/white just ends? does'nt go anywhere
I will do some test then.
Thank you
3.2 CAB 05-06-2008 11:29 AM
What year and type of car are we talking about here???
HarriTiidus 05-07-2008 01:40 AM
911T 2.4 72year.
