Help with trailing arm for 1976 911?
When I check the Pelican part numbers for trailing arms it shows a different part for a 1976/77 and 1980/89. Is there a difference in trailing arms or can I use one from a 1980?
Thanks, Blair. |
AFAIK, the only difference is the mounting arrangement for the rear sway bar drop link. Up to '77 alloy control arms use a ball pivot attachment; 77-on use a threaded hole.
Hope this helps, Sherwood |
Thanks for the information. Can you modify the '80's arm to work with a '76?
Blair. |
I checked the forum some more and found this information if anybody is interested.
http://forums.pelicanparts.com/porsche-911-technical-forum/381841-77s-sc-drop-link-conversion-questions.html?highlight=trailing+arm |
| All times are GMT -8. The time now is 12:36 PM. |
