Engine Rebuilder Question
CAN ANYONE RECOMMEND A GOOD ENGINE REBUILDER IN THE MASS CONN AREA?
MY ENGINE NEEDS REBUILDING AND I DONT WANT TO SHIP IT TO CALIF. NEED ADVICE. ITS A 73 2.4 S THANKS ,WALT(BUCKO)http://forums.pelicanparts.com/uploa...1210107101.jpg |
why not consider installing a larger engine. When my present engine blows up I'll go w/a 3.4 & carbs etc.
it appears that your car is personalized so stock isn't an issue. did you figure the cost of rebuilding? |
Do it yourself. Cheers, Mike :D:D:D
DO NOT send it to M.M. here in Cal..... If thats where you were thinking of sending it.
Auto Associates of Canton CT. No question...and no worries.
If I do you a favor and don't suggest MotorScheister, do you promise to turn the caps lock off?
| All times are GMT -8. The time now is 02:10 PM. |
