joetiii's Avatar
Octane requirements
Don't have a manual to check but I'm looking to find out is what the minimum octane requirements are for a 3.0 w/ 9.3:1 compression?
joe
'69 911 E Targa - aka "RoxiE"
Old 03-27-2008, 03:49 PM
dzls rok's Avatar
i try to use a quality premium grade. chevron, shell, 76 etc.
Old 03-27-2008, 04:31 PM
joetiii's Avatar
In Mass. we can select from 87, 89, 91, 93 & 94 Octane on the street. I usually go with the 93, but I thought the US 3.2s & 3.0s could run on 91.
joe
Old 03-28-2008, 10:44 AM
joetiii's Avatar
anybody?
joe
Old 05-07-2008, 06:17 PM
better to be safer than sorry.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-07-2008, 06:21 PM
2Utes's Avatar
My 1982 911SC Manual says:
Fuel Supply
Regular, 91 RON (87 CLC on U.S. fuel pumps), gasoline, UNLEADED FUEL ONLY. If regular fuel of sufficient quality in not available, use high-octane fuel or mix regular with high-octane fuel.
In Oregon, I use premium fuel which i believe is 91 on the pump label and have no problems.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 05-07-2008, 07:17 PM
Air Medal or two
afterburn 549's Avatar
Depends on the C/R
Some one here has a chart............................................. ......
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-07-2008, 08:21 PM
gas has become crap to start with.
911 upper cylinder areas is inadequately cooled imho.
unless your using digital data acquisition use only high test.
Grady posted some great info on engine monitoring
CHT probe placement
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-07-2008, 08:38 PM
Hester's Avatar
+1 Its a little depressing. We can build and tune the snot out our toys but we'll always be limited by the fuel that is available.
Here is a good thread on Rennlist: http://forums.rennlist.com/rennforums/showthread.php?t=419556&highlight=octane
If I were you, I wouldn't use anything less than the best gas I could buy for my Porsche. The difference in price is negligible.
Have you ever seen a piston with a hole burned in it from low octane gas that detonated?
Donald
70 S Coupe
03 SLK
01 FXDX
05 Police Interceptor
Old 05-07-2008, 09:51 PM
