Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
oil line backdate
I'm in process of backdating my oil lines for my header installation and have a question.
Where does the bracket on the end of this line attach too? It locates right at the engine oil cooler rubber hose.
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-12-2007, 10:21 AM
to one of the bolts on the sheet metal. for some reason the tabs are bent down from shipping
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-12-2007, 10:35 AM
Chuck Moreland's Avatar
It attaches to a weld-nut that is on the engine-surround sheet metal.
Unfortunately the surround sheet metal around that weld-nut is flimsy, and the nuts commonly tear away. If yours is still intact, treat it gently.
Always use a second wrench to hold that crossover pipe when tightening the oil line tube nut. Never rely on that little bracket to stabilize when tightening.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-12-2007, 10:36 AM
Stahlwerks.com
jhelgesen's Avatar
Thanks guys, I'll go in search of the bolt tonight, see what I can find.
John Helgesen
Old 01-12-2007, 10:56 AM
Stahlwerks.com
jhelgesen's Avatar
Hey guys, does this look about right? I'll bend the tab up to meet the bolt.
John Helgesen
Old 01-15-2007, 04:17 AM
dtw dtw is offline
GAFB
Yep - that's how it is on my '72.
Thanks for the look at your oil system - I'll be doing this in a week or two on the '77 I just bought...or is it a '76? Meh, all these midyear cars look alike...
Several BMWs
Old 01-15-2007, 06:55 AM
SP2 SP2 is offline
SP2's Avatar
Hey John,
Cool, thanks for posting that pic. I have my engine out and couldn't understand where these new oil lines go. Can you post a pic of the other oil line when you get it in? Thanks!
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 01-15-2007, 07:20 AM
safe's Avatar
That looks like mine, had to force it a bit into place.
The angle of the oil line installation is a little different on mine, not sure how its supposed to be.
Magnus
Old 01-15-2007, 07:47 AM
Stahlwerks.com
jhelgesen's Avatar
FYI, the reason I ran the new line to the inside of the old line is for tire clearance. My 9x17's had about 3/4" clearance to the line when on the outside, but this was with the wheel up in the air, I'd expect a hair more clearance when the car is on the ground.
John Helgesen
Old 01-15-2007, 08:31 AM
safe's Avatar
FYI, the reason I ran the new line to the inside of the old line is for tire clearance. My 9x17's had about 3/4" clearance to the line when on the outside, but his was with the wheel up in the air, I'd expect a hair more clearance when the car is on the ground.
Good point! I will check the clearence of mine before I fill it up with oil.
Magnus
Old 01-15-2007, 08:50 AM
RideShoot&Drink's Avatar
Send a message via Yahoo to RideShoot&Drink
Discovered this thread, and have some questions. I'm dropping 3.6 with B&B exhaust into 87 chassis. Do I need same oil lines or there is more to it? Thanks in advance.
I'm in heaven, when I drive my nine eleven...
Old 05-07-2008, 07:49 PM
