partial engine drop to replace throttle bellcrank bushings on CIS engine?
Hello everyone,
The bushings for the throttle bellcrank on the top of my CIS engine have disintegrated and need replacement. Can anyone advise how to get access to this area for this repair? If I I want to avoid disturbing the CIS (since it is running well despite having many older parts), is a partial engine drop the right way to go? I couldn't find dedicated information on doing only a partial drop. Any suggestions for what to leave alone relative to the full drop (I have Wayne's books and the Bentley manual for this) would be greatly appreciated! I am a little intimidated by the engine drop process, and any other tips or encouragement would be welcome too!! Thanks!! Brian |
I performed this very task on my '76 911S (original 2.7L engine) last winter. I also did the bellcrank bushings on the driver's side of the trans. Neither one required a partial engine drop in my case. That being said, both jobs were a pain but very do-able, especially if you have long fingers! You might find, as I did, that the available brass bushings did not fit very well and required some minor machining. Available plastic bushings might fit better. Lube everything thoroughly and make sure that you get full throttle plate opening with a full accelerator pedal when you are done. Adjust cable as necessary to achieve full throttle.
You should be able to get to that without dropping the engine. Take the snorkel off the air box and disconnect the stuff going to the air box on the driver's side of the engine bay. You should be able to get at it. Three 13mm bolts (I think, they might be 14mm) is all it takes to remove it.
Well, that and the springs/linkages. At your discretion you might find it easier to take the throttle body & decel. valve assembly off the CIS since it's on that side too, although I found it to not be that much in the way - you can work around it. |
I just replaced mine with the engine out and don't think that a partial drop will do you much good as they are at the back and on top. By doing a partial drop, I don't think that you will gain anything as the motor will just be lower and you still need access. I think that if you remove all the heater plumbing, and airbox cover you can get to them but it will be tight and your back will probably hurt from leaning in over the engine.
Thanks Howard, Jeff and Mike. I'm glad to hear this should be doable without a drop. I've got some plastic bushings on hand from Pelican, so I hope to give it a go this afternoon.
Thanks again! |
Regarding full throttle adjustment: The "stop" should be at the accelerator pedal, not the throttle plate. If the throttle plate is not fully open at the stop, adjust it at the transmission bell crank. While there, look at those bushings, too.
CIS Throttle Console.............
If your engine still has all of the stock brackets,etc you should find that there is a support bracket held on by the throttle console nut closest to the front of the car. It supports some of the hoses/fuel lines that cross in that area. Once you get the linkage disconnected and the 3 nuts and washers off and accounted for (don't drop anything!) you should be able to lift the support bracket about 1/2" and move it out of the way. Also, there is a throttle return spring that hooks on one of the intake pipes and on the throttle bellcrank. Be certain that you take a good look at where it hooks. Then the throttle console should simply lift off the engine. As mentioned earlier, the space is somewhat tight and some extra care is needed while putting the washers and nuts back in place. This is not a terrible job, but it does require some patience. Good luck!
Just wondering how did you determine your bushings are shot when the bellcrank is so hard to get at and see?
I did this on my 83, as part of replacing the engine thermostat o-ring and pressure switch. I don't know how anyone with an SC can replace those bushings without a partial drop!
| All times are GMT -8. The time now is 02:35 AM. |
