Guest
Posts: n/a
I have a problem with the cooling fan rubbing on the housing by the crankshaft pulley. When I took the belt off of the fan and was able to check the alternator bearings I noticed their was a moderate amount of play. What I was wondering, can the alternator bearings be adjusted to take up the play or do I need a new alternator.
sorry about the triple post ------------------ Ted Stringer nuke3@juno.com '84 911 Targa [This message has been edited by Ted Stringer (edited 05-29-2001).] |
Guest
Posts: n/a
I just had my alternator rebuilt for around $125, and they installed new bearings and other items.
------------------ Michael '78 911SC Euro |
Guest
Posts: n/a
Ted,
Make sure you don't have a cracked fan housing first. I had a similar problem and it turned out to be two cracked blades on the fan housing itself. |
