-   -   Car will not go into reverse gear - Help (http://forums.pelicanparts.com/porsche-911-technical-forum/40806-car-will-not-go-into-reverse-gear-help.html)
beagle911 05-29-2001 05:57 AM
I have a '77 930 w/4 speed trans. I can not seem to find the reverse gear. The usual 'spring resistence' I normally would feel when moving the shift lever to the left and forward does not seem to be there. It is like I have lost the reverse shift position completely. I am goning to try to remove
shift cover and take a look. Any suggestions on what I should be looking for.
When it was working I never had any problems with any of the gears. I am hoping it is just a linkage type of problem. Any help will be greatly appreciated.
Thanks.
john walker's workshop 05-29-2001 08:03 AM
sounds like a worn out bushing problem. the shift coupler bushings just break and fall out. easy to see.
