Florida goes 10% ethanol and the solution is...
What have you guys done to your 911s once the fuel becomes 10% ethanol? Florida says 10% ethanol fuel is going into my 3.2 from now on. It's official huh.
The newspaper writes that gas stations do not tell us one way or the other. I put in premium (every time for many years) at what 3.95 gallon and now they dilute it 10% more? Regards,
Bernard |
I've been exposed to 10% eth for years here in Jersey. No ill effects noted on my '76 911S, '82 Kawasaki or '53 Nash. That being said, try not to let it sit in the tank all winter (though I do).
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
Here in Oregon they have gone to 10% ethanol year round (used to be winter only). I add Stabil to each tankful and pray my 35+ year old CIS does not rust from the inside out.
Monkey Butt Forespin
The Ethanol will loosen debris / contamination in the tank. It will also absorb more water. Drain the tank down as far as possible before putting in the 10% Ethanol fuel. Add a bottle of dry gas. Change the fuel filter. Change the fuel filter again after a few tanks if you drive regularly, or after a month or so, whichever comes first.
![]() Change the filter annually from now on. That's what I did, no issues on my '84 3.2 w/ 10% fuel. ALSO: IIRC, It's MANDATED they post the additives (MTBE previously, 10% Ethanol content etc.). Look for a sticker on the pump itself, most attendants have no clue during the changeover.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
No problem with 10%. The original SC manual says so, and it works just fine. 91 octane. But 15%--forget it.
'03 Boxster ***** '82 911SC **** '98 BMW Z3 ** '87 300Z *** '80 BMW 320i **** |
The Puff.
That dry gas stuff is awesome
. I used it when my tank was leaking . How do you guys get the tight bolts off of a fuel filter?
Ahem....
Dry Gas? No way! Why? Dry gas is yet more alcohol into your fuel system.
