-   -   wierd click in the clutch pedal (http://forums.pelicanparts.com/porsche-911-technical-forum/408327-wierd-click-clutch-pedal.html)
runfaster 05-08-2008 05:18 PM
Hey guys,
I need a little help. I have a 86 3.2 and everytime I engage the clutch pedal I get a single knock at exactly 3400 rpm. It just goes clunk and I can feel it in the center of the clutch pedal. Sometimes it happens at different rpm's but about 90% of the time it is almost at the 32-3400 rpm range.
Is it my clutch cable going out?
Cheers,
Craig
runfaster 05-08-2008 06:08 PM
Look's like nobody has had this problem. I will change out the clutch cable and omega spring tomorrow to see if it helps.
Cheers,
Craig
runfaster 05-09-2008 05:38 PM
I feel like a guy all alone in a room talking to a mirror, but I will follow up just in case anyone else feels the same clunk in the clutch pedal at the end of every clutch engagement.
I went to replace the clutch,omega spring and the clutch pedal spring and for the mean time it has fixed problem. I think it was the clutch pedal spring because the new one felt smoother when I was messing around with it before I hooked everything back up.
Just a heads up on replacing the clutch pedal spring, it is a real ***** to get back on. I finally got a big 12 inch regular screwdriver and knotched a groove in the middle of the blade with a bench grinder, this gave the spring a place to rest while I pushed like hell on the end of the spring so I could slip the hook back on to the solid post on the pedal cluster.
Cheers,
Craig
