I've got my 911 up in the air and I can't get the pads out! There are 2 small pins or bushings inside the piston that won't detach from the pad.
Any suggestions or am I missing something? |
I pulled this from the waterpumper forum. Hope it helps.
http://forums.pelicanparts.com/porsche-996-997-forum/511593-996-brake-pad-replacement.html
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
That's exactly what I found out and thanks for the tip. Great read. They need to be peeled off prior to removal. What's interesting is that the new pads didn't come with the factory type dampers, which makes me believe they're not needed.
Any comments? |
I don't think they usually come with the pads, you have to buy them separately. I would just reuse them even if they're not stuck to the pads. Been doing that for years with no problems.
'87 911 Coupe '95 911 Coupe '04 911 GT3 '98 Jeep Wrangler |
Tony
Yes I highly recommend you use/reuse them as you will have severe squealing if you don't.
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
