1-6-2-4-3-5-1-6-2-4-3-...
pope's Avatar
Fuel hose size and other fuel Qs
I had leakage from hoses near the fuel pump and so I had to replace some of them. To be on the safe side, I want to replace all the hoses because they look pretty old. I guess I have to change the fuel filter too. So I have some Q's:
- is this filter OK for use with this specific setup (2.2E with webers)? If so, should I change this also?
- which size of hose should I use for the hoses in the engine compartment. They all look the same size to me.
- there is a clamp a few inches to the left of the fuel gauge. What is that doing there? It's clamping the hose that sends fuel to the carbs. Is it like a regulator?
- should I also change the two little hoses on the carbs or are those included in the weber rebuilt kit?
- here are a couple of pix of my fuel pump. They're off a cell camera so they're not that good but maybe someone can tell me which pump this is and if this info helps answer some of the questions here:
'70 911E Coupe, Webers 40IDA
Old 10-06-2007, 08:40 AM
pope's Avatar
bump
Old 10-08-2007, 01:34 AM
pope's Avatar
Anyone? At least the fuel hose size question. I need to change those very soon.
Old 11-25-2007, 01:22 AM
pope's Avatar
Will this filter work OK with the webers?
Old 02-10-2008, 04:21 PM
I don't know what kind of filter that is?
In the US a routine auto store fuel filter is rated around 10 microns. 911 carbs have a tendency to be dirty fuel sensitive. I used a marine gasoline fuel filter with 2 micron replacable element. Other options are 5, 10 microns.
A local pope uses the Racor gas fuel filter that has replacable element and able to withstand 100psi. Costs around $75US and elements may cost around $15-25US.
My Racor is a different model with spin on external element, which I do not recommend for others.
Does that unit come apart to replace an internal filter ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-10-2008, 07:38 PM
Danny_Ocean's Avatar
What are the numbers on the bottom of the pump? That will tell exactly what you have.
Old 02-10-2008, 08:05 PM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
It looks like the part with the gauge is a fuel pressure regulator to control your fuel pressure. The MFI fuel pump puts out higher pressure than the carburetors can handle. If I remember correctly carbs need about 5 to 8 psi and I'm not sure what pressure MFI runs at.
Most of my fuel lines are 7.5mm x 13mm Cohline.
13-31-1-469-781-M20
Fuel Hose, (7.5 mm ID, 13.5 mm OD) High Pressure, (quantity as needed, priced per meter)
Brand: Cohline
$5.50
I think I ordered 2 or 3 meters for my car. I also have 8mm fuel line but I think that is the fuel line from the tunnel to the driver's side metal pipe. I haven't done the fuel pump lines yet.
Since you have a fuel return line you can do a Weber recirculating fuel modification pretty easily, do a search and you'll find some great threads.
-Jess
Old 02-10-2008, 08:12 PM
MFI puts out 14.2 psi. (1 bar with 2 bar relief). We can't be sure that's an MFI pump, however, without seeing the #'s. Kinda looks like a 0001 at the end though, huh? I have a rebuildable pump for carbs if the pope needs one...I'll gladly take that old greasy thing off his hands if necessary.
Old 02-10-2008, 09:32 PM
pope's Avatar
Part # 0 450 135 002
This looks similar to a fuel filter for an MFI (which my car used to be before it was converted to webers).
The pressure gauge goes up to 3 PSI when the pump is on and a bit higher when the engine is running (but it's been a long time since I checked that).
Old 02-11-2008, 03:04 AM
these are PMO regulators with a return line as far as I know.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-11-2008, 05:03 AM
What is the part # stamped on the bottom of the fuel pump?
Old 02-11-2008, 06:57 AM
pope's Avatar
Danny, I gotta squeeze under the car to get that. I'm going to do it tomorrow probably and I'll tell you. I believe it must be an MFI pump though.
For the time being, I'm reading a lot of threads on fuel delivery and I'll post links to the relevant ones in here as soon as I compile it.
Old 02-11-2008, 08:42 AM
Not important, as long as you have a pressure regulator installed, which it appears you do.
P.S. - My barber is from Romania and she is HOT! Tell me something I can say to her in your language to make her get undressed...
Old 02-11-2008, 01:18 PM
pope's Avatar
Haha. I'm not Romanian actually and my Romanian is a bit vulgar, don't know if you'd get the best result from my suggestion.
Old 02-11-2008, 02:02 PM
pope's Avatar
So, I've read loads of threads all day today. Most enlightening I found to be the following:
+ Brilliant thread that focuses on MFI (thread subject is misleading): Braided Fuel Hose for a 72T MFI
+ Webers and fuel pressure regulators, yes or no?
+ AKA Tyson's recirculating system: 2.7RS fuel delivery system
+ And its application: Carb Plumb Loop pic
+ Weber fuel recirculation- Questions
Now, my setup looks a lot, if not exactly, like this one. Down even to the MFI filter and how it looks like it's connected.
And here's a diagram and a couple of pix to make it clearer:
I think it's clear from what I've read that I will need a fuel pressure regulator. But I'm not sure which one I should get (brand and model) and where exactly I should install it ( I assume on the return line right after the gauge).
I'm not sure what the Tyson method would look like because there was no diagram anywhere and it wasn't 100% clear to me from the text. Is it worth me going to that one or should I stick to what I have?
Finally, should I keep the MFI filter as it is connected or should I replace it with this:
Old 02-11-2008, 02:43 PM
AutoBahned
RWebb's Avatar
PMO make a good one - about $40 -- about $80 if you wnat the higher bling-factor billet one
incl. a gauge
not sure re MFI - it is very high pressure
Good job collecting the threads - that will help others long after you are motoring along
the Racor is the std. high zoot fuel filter - I hope to add one before EtOH is required here...
Old 02-11-2008, 04:34 PM
pope's Avatar
It seems that PMO does not sell them on their own and I found reference on their site to the Holley regulators. I found this page which has two versions that seem to fit my requirements - the 500 and the 804.
The question is, how do I hook this up to my plumbing?
Old 02-19-2008, 07:42 AM
pope's Avatar
0 580 970 001
Old 02-19-2008, 03:30 PM
0 580 970 001
That is the correct pump for MFI.
Old 02-19-2008, 04:12 PM
pope's Avatar
Can anybody help with my pressure regulator issue please?
Old 02-22-2008, 11:08 AM
