Mothy's Avatar
Send a message via AIM to Mothy
Wheel Adaptor to spacer conversion
By changing to steel wheel nuts instead of the standard enclosed alloy nuts I have discovered that I do not get enough thread engagement when I fit my after market rims - looks like the mounting surface is slightly thicker than the one on the standard rims. (my standard rims are fine)
I use 1" adaptors on the front and 2" at the rear so I believe I have 2 options:
a) install slightly longer studs in the adaptors
or
b) press out the old adaptor studs, and install much longer studs in the hub, using the old (studless) adaptor as a spacer.
Has anyone done a) or b) before?
We are only talking about a couple of mm here but its enough to fail scrutineering at a track day.
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 05-11-2008, 07:52 PM
cantdrv55's Avatar
Check out this thread from a few years back on how to replace wheel studs for longer ones if you want to use wheel spacers. I'm going to do this myself.
Wheel Stud replacement...A pictoral..
Old 05-11-2008, 10:12 PM
