blau911's Avatar
Bistributor info needed for 911 2.7RS spec motor
Installed a 2.7RS spec motor in my 73T. Mechanic advised that it was set up for Petronix pointless ignition. My mechanic advises that I am better off going back to points. He said that I can use a T distributor for the motor since the advance curve is very similar. However, I will be losing some of the power of the motor by doing so. Can anyone advise whether I am better off buying another distirbutor and having it recurved so that I can maximize performance or is the difference negligible?
Mechanic also said that I will be disappointed with the solex cams as they are significantly milder than the original S cams. I have heard otherwise. Any running a 2.7RS spec motor with Solex grind cams?
Old 05-10-2008, 12:53 AM
BURN-BROS's Avatar
The 2.7RS has less mechanical advance and more initial making for a peppier motor in the lower rpms. Total adavance is close to the same for both dizzys. I have recurved quite a few to RS spec for customers doing the same thing as you.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-10-2008, 05:14 AM
blau911's Avatar
So the question is since the curves are so similar, am I better off having my 911T dizzy recurved or just leave it the way it is?
Old 05-10-2008, 06:52 AM
BURN-BROS's Avatar
Yes, recurving the distributor is the better of the two choices.
Burnham Performance
Old 05-10-2008, 07:42 AM
blau911's Avatar
Am I losing less power having a T distributor curve since I have a slightly milder cam grind (solex versus S)?
Old 05-10-2008, 08:03 AM
BURN-BROS's Avatar
RS spec motors have little in the compresion dept. The Solex cams may help to increase dynamic compression but you will still lose power not having more initilal timing.
Burnham Performance
Old 05-10-2008, 08:26 AM
They're similar in that they curve, but they're different. As Aaron says, the S curve, along with more static ignition timing (5ºBTDC instead of 5ºATDC) provides more advance at lower rpm for increased engine torque. In addition, the max. advance curve on an S-spec distributor is shorter due to more advance at initial timing. The overall advance is shorter by about 4-5º.
It'll work with the T distributor, but you'll be leaving some power on the plate.
Sherwood
Old 05-10-2008, 11:14 AM
