initial's Avatar
How dumb am I? Am I pressing my hub with the old bearing race still on?
Hi,
I think I may of outdone myself!
Based on the following picture, can you confirm that I am indeed trying to press my hub in my new bearing (it's nicely jammed in there) with one of the races from the old bearing still firmly attached to the hub?
Does anyone have a picture of normal hub to share?
Can I really be this dumb?
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD
Past - 89 911 3.2 silver cab
Old 05-10-2008, 06:39 PM
MEMBER # 930
waynesco1's Avatar
You are not . OK now jist slow down . Look at top heading on this page ( SEARCH ) enter rear wheel bearing removal. Lots of info good luck. Helps to remove entire arm take to machine shop using hyd press for bearing and look at tortion pivit ( monoball) the best investment to hold wheel alinment they dont have any deflection under loads check elephant racing products >
Old 05-10-2008, 07:04 PM
