H4 paintable fit over H1?
Will the painatble rim that goes over the H4 lights work on a set of H1 lights?
I ask because the chrome on my H1's need cosmetic work and I like the look of rims painted to match Shawn
Shawn 77 Targa with 2.7 My never-ending work in progress that has been off the road since Mar 2004
Yep, they do. I took the painatble H4 covers to a hot rod chromw shop, and had them chromed!
Vic |
Yes. I have them match painted, and installed over H1's.
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
AutoBahned
what about the "non-removable" adjusting screws?
The trim ring covers the screws. You need to remove the trim ring to adjust. One bolt, 2 seconds.
Note: you need to change to the H4 mounting bolt to attach the Trim ring. 911-631-033-00-M260 (7.75 each, 2 needed) and 911-631-132-00-M260 (1.25 each, 2 needed) available from our host.
AutoBahned
on my H1s the adj. screws are built into the trim ring...
Yes, mine too. This is a ring that goes OVER that ring. Same chrome ring with adjustment screw is underneath it.
![]() ![]() same car, different lighting situations.
AutoBahned
huh - now that _is_ trick
