Need Info. Re: Millia Miglia Cup 2 18" wheels
I have a set of 18X8.5 and 18X10 Millia Miglia Cup 2 Replica Wheels (Italy) and I want to list them for sale and I don't know much about them. The PO of my 95 993 included them as an extra set of wheels with the the car. I have no need for them and want to sell them.
However I don't know the offset or material they are made of and what car(s) they will fit. They were used briefly on my NB 993 at the track, and they are in very good condition. They cleaned up well and look good. See photos below. Anyone have info?...and what are they worth? I will put them on eBay if I can find out more about them. Thanks! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Jerry
1995 993 Carrera, Guards Red Coupe (current) 1987 911 Carrera, Marine Blau Metallic (06-08) Gone but... 1965 Yellow Mustang Convertible (65-05) __________________________________________ It is always a good idea to keep the pointy end going forward as much as possible. |
Monkey Butt Forespin
Jerry, look inside the back, you'll likely find the offset stamped in the back (might be 52-55mm??)
I sold a set of MM Cup 1's with good tread tires for $500 for the set a couple of years ago, but that was LOW.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
I have seen them on Boxsters, not sure if they were using spacers. They looked really good, kinda like 17 inch fuchs a bigger than life version of the original.
I think they will fit 964,993, 996 based cars.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
84_Carrera...Your are correct Sir! Offsets are ET52 for the 8.5s and ET47 for the 10s.
I assume that these are cast wheels? Thanks! Jerry
