MBruns for President
JeremyD's Avatar
So need to order a new window motor what's LEFT?
or Right - I need to order a window motor for my car - passenger side - which is it in porsche speak? left or right? Thanks in advance.
Old 06-09-2009, 07:27 PM
I put a right one on my passenger side last week. Bit of a pain working in the door. Torx head bolts too.
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 06-09-2009, 08:25 PM
passenger side is right side
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-09-2009, 10:45 PM
JeremyD's Avatar
Thanks - that's what I thought
Old 06-10-2009, 06:06 AM
Before you go buying a new motor, try jumping it straight from the battery with a little wd40. My passenger side motor got some water in it and froze from lack of use, nothing wrong with motor just stuck. Worth a try.
Old 06-10-2009, 09:14 AM
JeremyD's Avatar
Thanks = I'll try that - I tried a direct connect to see if it was the switch (replaced last year) and it would not budge - blew the fuse.
I'll take it out and try again with a little WD-40
Old 06-10-2009, 09:36 AM
