911 throttle sticks
i have a 73s and the throttle sticks on start up or just driving normally any causes i'm pretty sure it's the cable sticking but want other options as well
thanks
Old 05-12-2008, 01:59 PM
Check the plastic pivot bushings that support the linkage arms at the brake pedal assy, gearbox and intake manifold. They eventually deteriorate and fall apart. Disconnect the throttle cable at each end to help isolate where the linkage is hanging up.
Sherwood
Old 05-12-2008, 02:06 PM
my throttle cable is attached right to the pedal not sure if it's a make shift deal or that's the way it is but the car is from europe so not to sure on what i got.
Old 05-12-2008, 02:42 PM
ManaMan's Avatar
Check the throttle connection by the gear box, look for a frayed cable.
'77 930 euro project
Old 05-12-2008, 03:06 PM
Zeke's Avatar
You might want to post a pic of that. Meanwhile, have you checked out the linkage down by the trans. If there's cable down there, someone has mickeymoused the original linkage. There is no cable on a '73 S. It's all hard parts.
Old 05-12-2008, 06:38 PM
Brorag
Brorag's Avatar
clamp interferance
mine was catching on the clamp that holds the rubber boot from the throttle body to the intake. I repositioned the clamp and that fixed it.
Old 05-12-2008, 07:16 PM
dshepp806's Avatar
Brorag: Have you a pic of this?
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-12-2008, 07:27 PM
"farking Porsche hero"
Rich Lambert's Avatar
Check for worn motor & tranny mounts. The engine moving around could cause the linkage to ride on the engine tin at the left front of the motor. If that's not it, check all the ball & sockets in the linkage and the bushings on the tranny bell crank. While you're checking them, you might as well clean & grease 'em all up too. They're all pretty easily accessable either in the cabin under the floorboard or under the car on jackstands. Pop them apart with an 8mm open end.
When I took the linkage on my car apart, the bell crank bushings on the tranny were greasy sludge and little bits of white plastic.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 05-12-2008, 07:28 PM
Brorag
Brorag's Avatar
pics
no, but gimme a minute and I'll go take one...................
Old 05-12-2008, 07:41 PM
Brorag
Brorag's Avatar
here's the pic
I had the rubber boot off checking the throttle body; when I reinstalled, the clamp ended up further to the left, so that when I tightened it, the screw head interfered with the throttle arm. Got real exciting; actually felt "detent" in pedal. I repositioned the clamp and the problem went away.
jd
Old 05-12-2008, 07:50 PM
Zeke's Avatar
Yeah, but jd, that's not a '73. His is all rods and ball joints.
Old 05-13-2008, 08:05 AM
not sure about your modle year, but my '86 throttle binds with the clutch linkage to the right of the pedal assymbly. Just check there to be sure. This only happens t mine when the clutch is depressed.
1986 944 Turbo - Guards Red
Old 05-13-2008, 11:00 AM
thanks for the input i'll try to take pics of the throttle cable it's a euro 73 and a half with a 74 2.7 in it. not sure if it is but i'm pretty sure it's all original to the car
Old 05-13-2008, 02:14 PM
Old 05-13-2008, 02:23 PM
Old 05-13-2008, 02:26 PM
there's somecs of the car and the inside.
Old 05-13-2008, 02:42 PM
Zeke's Avatar
Ah well, 73.5 and CIS does make a difference. Did you say 73 and a half before and I missed it?
Old 05-13-2008, 06:31 PM
yes it is a 73 and a half with cis.
Old 05-14-2008, 06:04 AM
