-   -   Gas Guage Sending Unit (http://forums.pelicanparts.com/porsche-911-technical-forum/409070-gas-guage-sending-unit.html)
GLASEM 05-13-2008 09:26 AM
My gas guage has been reading erractic lately so I pulled the sending unit for a cleaning.
Took it apart and found some varnish on the float slides. Checked guage out of the tank got great readings.
Put it back in and bolted down what I thought was OK. No readings.
Removed several times OK out of tank. Put it back no readings
Finally got it to work back in the tank if I barely tightened the nuts.
What would cause the unit not to read if the nuts were tightened more than they are now?????
BTW did replace the gasket
RWebb 05-13-2008 11:07 AM
bad ground or bad signal wire?
if tight = no sliding, seems there would still be a reading (tho static)
