older alt fan housing fit my 85
does the 901 part number (later fan housing ie....early SC's) fit my 85 carrera which is a 930 part number? my fan housing is cracked.
thanks
david
Old 05-11-2008, 05:58 PM
poorsha's Avatar
Your alternator will not fit.
Old 05-11-2008, 06:27 PM
can it be fabricated to fit?
Old 05-13-2008, 12:54 PM
North Coast Cab's Avatar
The housing will fit your car. It just needs to be used with the early alternator.
Your alternator is not interchangeable without major modification to the housing.
1985.5 944 GTS
Old 05-13-2008, 01:53 PM
gtc gtc is offline
abides.
gtc's Avatar
Edit:
Lol... whoops... I actually bought mine from North Coast Cab ^^^
Graham
1984 Carrera Targa
Old 05-13-2008, 02:04 PM
You can tig weld your cracked housing for less money and headache than replacing it. Call up a mobile welder and they will come on over and take care of you.
Old 05-13-2008, 02:14 PM
David:
My '84 has the same alternator and fan housing as yours. On mine, 3 of the 4 vanes had cracked, almost all the way through. I pulled it on Sunday, and thought it was beyond repair. I had to try to save it though. I took it to a guy who says he can weld anything.
I got it back this morning. It looks really really rough, but it's solid. I am thinking about filing away some of the glop weld material and then having it glass bead blasted. I'm not sure how much is safe to remove though.
Anyway, I can post pictures if you want. It cost me about $180 so far vs $500 for the Vertex one, which I understand has some fitment issues. At this point, I know my old fan housing is fixed, it will fit back perfectly, and I am wrestling with costmetic and air flow questions.
Russ
Old 05-13-2008, 02:53 PM
