-   -   Another O2 Sensor Light Question (http://forums.pelicanparts.com/porsche-911-technical-forum/409316-another-o2-sensor-light-question.html)
p911sc 05-14-2008 02:35 PM
My Oxygen Sensor Light came on today. Pulled the speedometer to reset the mileage counter and don't see a reset as described in Bentley Manual and in other posts. Any ideas???
Thanks in advance.
Rickhttp://forums.pelicanparts.com/uploa...1210800892.jpg
ischmitz 05-14-2008 03:27 PM
This is the speedometer you are holding there. You should see a box behind it in the open hole where you pulled out the speedo. The reset knob is located on that box.
p911sc 05-14-2008 03:29 PM
I figured it out. Reread one of superman's posts and followed the wires around. The box sits about 8" behind the speedometer. I was able to reset the button with a chopstick, which is a permanent tool in tool in my toolbox. I also use chopsticks to plug the distributor's vacuum lines when setting the timing.
Rick
http://forums.pelicanparts.com/uploa...1210804075.jpg
p911sc 05-14-2008 03:31 PM
Ischmitz,
Thanks for the reply.
Rick
