joseph222's Avatar
Send a message via Yahoo to joseph222
B&B muffler - odd sounding
My 89 carrera has a stainless steel B&B muffler (from PO), that was really nice sounding until recently. It sounded so good it was all but impossible to roll the windows up.
However, it has started producing an irritating vibrating buzz between 2-4k rpm.
Almost sounds like an exhaust leak, but we've determined it to be a vibration inside the muffler itself. Like part of something has broken partially loose. Applying pressure with a stick against the body of the muffler, we can make the sound come and go.
Anyone have experience with a similar situation and tried a repair?
Any procedural tips or precautions appreciated.
Seems like perforated baffles are usually attached to the end pieces.
We were thinking of cutting that open to start with.
Comments? Observations? Suggestions?
Joseph
89 Silver Anniversary Carrera, "Pearl"
Not forgotten... 69 911E ~ 75 914-4 ~ 88 GP White Carrera
Old 05-15-2008, 07:45 PM
haycait911's Avatar
I fixed a similar problem once by drilling a hole and then threading in a long screw. stopped the noise.
Old 05-15-2008, 07:53 PM
joseph222's Avatar
Thanks haycait911 - Did you drill the hole into the side of the muffler body, or into the passenger side end piece?
Anyone else with suggestions/experience?
Joseph
Old 05-16-2008, 04:44 AM
fireant911's Avatar
I too had a very annoying noise from my B&B muffler that occurred within a certain rpm range. I loosened one of the muffler clamps and placed a strip of thermal cloth to stop these vibrations. I am NOT an advocate of B&B exhaust systems - I have since sold the complete system (heat exchangers and muffler) and replaced it with the stock exhaust and absolutely love it (as do my neighbors).
Daryl G.
1981 911 SC - sold 06/29/12
Old 05-16-2008, 04:56 AM
haycait911's Avatar
I drilled right where the noise was coming from. maybe I got lucky, but probably worth a try before cutting into things. if it works, you could overweld the screw head to prevent loosening. Don.
Old 05-16-2008, 06:10 AM
B&B had some issues with earlier mufflers with cracking, both internally and externally. You can see the extra bracing they welded on later models. Chances are that an internal baffle broke loose and is lightly vibrating against the muffler wall in that rpm range (typically a harsh point in the B&B range). I'm actually surprised you liked the sound prior to this, I had a system and couldn't take it, as has been the experience of a number of people on the board.
It depends on your preferred level of involvement as to how you fix it. You could try pressure at different points on the muffler body, and drill/tap a screw at the point where you find the best improvement from touching. Seems like a scattershot approach though. You could also ask B&B for a schematic of the muffler, and for their advice on how to go about it. At the least, you'd know the layout of the internals and could gauge where the break likely occurred.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 05-16-2008, 06:16 AM
1984-911 M491
Trog's Avatar
I've had the B&B 2 into 1 system for 8-months now and am absolutely satisfied. The sound is 'just' right and the system has performed flawlessly.
1984-911 TLC......SOLD
Old 05-16-2008, 06:45 AM
what do you think of your new gen5? sorry guys for not bringing anything to the table
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-16-2008, 08:09 AM
Unbelievable. Perfect. I still have to post a thread about it. Roadtrip to PA this weekend and I'm hoping the sun comes out so I can roll the windows down and listen to it.
89 Carrera 3.4
Old 05-16-2008, 10:02 AM
abit off center
cgarr's Avatar
I had a repaired B&B muffler then went with the much lighter M&K That B&B was like an anchor right where you don't want it!
______________________
Craig
G2Performance
Old 05-16-2008, 10:17 AM
joseph222's Avatar
Don - That's a good idea. Thanks again
Following Jgordon's suggestion, I talked to B&B today and they were helpful (although they don't release schematics). All of the internals are attached to the passenger side end piece. If we have no satisfaction with the screws, we'll open up the end piece and go from there.
Cgarr - how much weight difference do you think there is between M&K and B&B? I own both. I'll weigh them.
As far as the sound goes - mellow & powerful - I absolutely love it. Deep rumble at idle, a refined and muffled purr at mid-range with a nice bite at the upper end.
I've ran Bursch, Triad, SuperTrapp, and M&K. They each have their signature sound. But I've never had as many positive comments to the exhaust note as with the B&B's.
We can't all have the same opinion now can we?
Thanks to all for your help. I'll let you know what transpires.
Joseph
Old 05-16-2008, 12:54 PM
Mine came with the B & B muffler and I think it sounds pretty good.
Old 05-16-2008, 08:06 PM
Glad to hear it's working out. I have a number of changes in my engine - p&cs, cam, chip, etc so we're not even hearing the same note.
Interesting though that they're all attached at one end. Might be worth cutting a few patches and reaching in to tack it to the muffler body, that might help stop the noise. Likely you'll find the source though when you pop the end.
89 Carrera 3.4
Old 05-16-2008, 09:28 PM
