jeff1hughes's Avatar
Anyone have a spare cruise wire harness
Well, I finally found out why I can't hook my cruise control brain up...the PO cut off the wire harness! I'm happy and not happy all at once. I've solved the problem , yet now have to find what I assume will be a difficult odd ball part Any help on 1. finding the plug/socket that hooks to the cruise brain (which I do have), and 2. which wire goes to which pin? If I have to I will hook up the individual pins to the brain I just need to know wire/# combos.
Thanks for any help,
Jeff
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 05-14-2008, 04:14 PM
grateful user
don gilbert's Avatar
jeff i have a 82sc parts car that has the control and harnes still there. e-mail me and ill ship it
Old 05-14-2008, 04:33 PM
for a '81. should be the same for all cars with the brain up in the front trunk. later carreras had the brain under the dash.
206 637 4071
Old 05-14-2008, 04:37 PM
grateful user
jeff i was just going to cut the connector and give you some pig-tail to solder on your harness. if you want me to dig out the whole harness as jww did will need a little jack
Old 05-14-2008, 06:36 PM
I too can send you most of the harness, it has the connector and most of the wiring except where it picks up off of the guages and both Haynes and bentlry show where the hook ups are.
Lorne M.
83 SC
Old 05-15-2008, 10:28 AM
Don, I sent you a email, just wanted to follow up. By the way, do you by any chance have the little plastic appearance cover that goes over the wire connector too? Let me know what you want for everything.
John, I would much rather someone that needs EVERYTHING get a piece like you have. I don't plan on replacing it all at this time, and would hate to waste a GOOD complete piece by cutting it up. Thank you though.
Lorne, I appreciate the offer. If for some reason lines get crossed up I'll let you know.
I love this site, it really is a community - where else is there this much help, readily available to what would normally be considered a bunch of strangers.
Thanks.
Old 05-15-2008, 07:48 PM
