LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
naturally aspirated
Palum6o's Avatar
Things to bring to DE
Sorry if this was discussed, I tried the search first. I'm attending my first DE. Just wanted to make sure I remember to bring what I need:
Helmet
Stamped Tech sheet
Group listing sheet and schedule
Basic tools
The weather isn't looking to good for tomorrow over here, umbrella is on the list.
anything else?
Old 05-16-2008, 09:01 AM
Don Plumley's Avatar
Chair
Cooler with water, snacks
Tarp to put in paddock to lay stuff on
Oil
Windex/paper towels
Pressure gauge
I have a big checklist if you want it.
Don Plumley
M235i
Old 05-16-2008, 09:03 AM
Chair
Oil
Windex/paper towels
Pressure gauge
Don Plumley
M235i
Dont forget your car
Old 05-16-2008, 09:05 AM
abit off center
cgarr's Avatar
cigars
______________________
Craig
G2Performance
Old 05-16-2008, 09:06 AM
Registered Abuser
MT930's Avatar
A DE check list woul be great please post! I was just going to start one.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Here's my List
Don Plumley
M235i
Old 05-16-2008, 09:19 AM
911quest's Avatar
Murphys law......
If you think you will need it or it could break take it with you brake fluid torque wrench extra tune-up parts plugs cap etc. It's a DE but I have seen a few weekends ruined trying to chase down a two dollar part.
Tony Proasi
1969S
1957 VW Pickup
Old 05-16-2008, 09:23 AM
Driving member
jester911's Avatar
Don, that is a pretty good list.
I would add bringing a spare DME relay, Dist. cap and rotor and fan belt. I always carry these in my car anyway but at the track it is even more important IMHO.
If you have them then you probably won't need them.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 05-16-2008, 09:29 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
dont for get the camera so you can post some Pics!!!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-16-2008, 09:31 AM
joecrum's Avatar
Something to wipe that silly grin off your face...
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 05-16-2008, 10:08 AM
Driving member
jester911's Avatar
It is also important to bring all the required forms.
They are different for each club but here are a few I have had to bring.
Helmet form
Tech inspection form
Health form
Waiver
I usually have a large manila envelope I carry those and my numbers so I keep them together.
Jerry
Old 05-16-2008, 10:17 AM
David's Avatar
If you have adjustable sway bars, bring the tools needed to adjust them.
Old 05-16-2008, 10:34 AM
Noel's Avatar
Here is mine plus here is my nuts and bolts check for prep:
Track Prep List
Registration Stuff
 Signed/completed Tech Form
 Schedule and run group listings
 Driver’s License
Car Stuff
 Window Cleaner/ Paper Towels
 Motor Oil
 Extra Brake pads
 Brake Fluid
 Brake Bleeder
 Cover-Alls (Clean)
 Tire Pressure Gauge
 Racer Tape For Head Lamps/Marker Lights
 Tools (Wrench set and socket w/ toolbox)
 Jack / Stands
 Torque Wrench
 Wax/ Car Duster
 Quick Detailing Spray with Car towels
 Car Cover?
 Mirror Bras
 Funnel
 Jack Wood/ small ramps
 Rubber Gloves
 Work Gloves
 Magnets/ Magnetic numbers
 Helmet/ Gloves/ neck brace
 Knee pads
 Blue boxes with lids
Other Stuff
 Lawn Chairs (No need at Mid-Ohio)
 Sun Block/Hat
 Ant-Acid
 Magazines/ Books
 Bug Repellent if going to Nelson Ledges
 Camera Digital
 Wallet
 Maps/Directions
 Tent or Tarp for more shade (No need at Mid-Ohio)
 Air Mattress
Clothing
 Boxers
 Long Sleeve shirts and kakis/Jeans
 Rain coat/rain pants/boots / Umbrella if weather looks bad
 Jeans
 Running Shoes
 Glasses
 Bath Stuff (Including Contacts)
 Long-Sleeve T-Shirts
 Socks
 Ball cap
 Watch
Tools
 Yellow Tool box
 Pliers
 Multi-Screw driver
 3/8” Metric Sockets
 ¼” Metric Sockets
 3/8” and ¼” Extensions
 Spare Parts
o Fuel Pump
o Cap/Rotor
 Electrical Tape
 Brake Pad Spreader
 17mm Hex Socket
 Metric Allen Wrenches
 3mm Long Allen Wrench
 Mirror
 JB Weld
 Hammer
 Punch for brakes
 Wonder bar
 Crescent Wrenches
 Rubber Gloves
 Work Gloves
 Tape Measure
 Zip Ties
Nuts and Bolts Checklist:
Pre-Track Nuts and Bolts Checklist
 Left Front
 Caliper Bolts (2) – 19mm
 Caliper Bleeder Bolt (1) – 9mm
 A-Arm Bolts (4) – 17/19mm
 Tie Rod End Bolt (1)
 Pads and retainer Pins (2)
 Bearings
 Sway Bar mounts (2) – 17mm
 Brake Cooling Scoops & Hoses
 Strut Top Nut (1) – 22mm
 Ball joint nut retaining pin present (1)
 Lugnuts (5)
 Right Front
 Bearings
 Lugnuts (5)
 Left Rear
 Caliper Bleeder Bolt (1) – 7mm
 Swing Arm Bolts (6) – 17/19mm
 Alignment Bolts (2) – 19mm
 Lower Shock Bolt (1) – 22mm
 Upper Shock Bolt (1) – 17mm
 Sway Bar mounts (4) – 13/19mm
 Lugnuts (5)
 Right Rear
 Lugnuts (5)
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 05-16-2008, 10:36 AM
Need tools at DE?
Mike,
Welcome to your first DE. In case you need tool/s at your next DE, and don't feel uncomfortable borrowing it from other members, simply go to Dougherty's service trailer. Bill or Jim are always willing to assist DE drivers in their desperate moments. Enjoy and share with us your experience. Good luck.
Tony
Old 05-16-2008, 11:17 AM
Driving member
jester911's Avatar
One great thing about going to the track. If you forget something someone else almost always is willing to share with you. It is really impossible to bring every possible need but usually someone in the paddock has it within reason.
Jerry
Old 05-16-2008, 11:21 AM
The thing to do is find the sweet spot between on the one hand bringing nothing but a helmet and, on the other, preparing for LeMans. I used to bring stuff like spare brake pads and finally realized it'd be awhile before I drove hard enough to wear out the ones I had. You can always borrow tools; somebody will always be happy to not only lend them but help if you seriously break something.
Particularly if it's your first DE, you're not going to be tweaking swaybar settings and re-timing the distributor, and you're not even going to be doing anything with tire pressures other than making sure they're inflated and then some. You'll have plenty of time down the road to start playing with stuff like that, once you've found your way around the track and simply begun to absorb the basic stuff.
I'd suggest concentrating more on the comfort stuff--sunglasses, sunblock, something to drink, somewhere to sit, a tarp or blanket on which to spread everything out, big trashbags to cover things if it rains, good driving shoes, camera for fun, a carton into which to put all the stuff you remove from the trunk and glovebox, etc. etc. etc. than I would on worrying whether you have enough tools to do an engine drop. You'd be amazed how quickly the time passes between run groups; by the time you've unwound from the first session, it's time to line up for the second one.
Sure, bring a spare quart or two of oil and a funnel, have an extra fanbelt aboard, but stuff like brake fluid is a waste of space unless you have the kind of leak that would get you disqualified at tech anyway. You're _not_ gonna be going fast enough to boil it off. And if you are that fast during your first DE, the talent scouts will be all over you...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-16-2008, 11:35 AM
Noel's Avatar
The previous points about simple prep are good and I agree with them for your first and second seasons. The above lists that I posted were put together over my previous 7 seasons of DEs and serve mainly as a checklist for me. I obviously over pack. THere is never a problem borrowing tools, jacks, or parts from others.
Just bring oil, brake fluid and personal comfort stuff and you will be fine.
Old 05-16-2008, 12:26 PM
Noel, I did realize that yours was a serious race-prep list, not intended as first-DE advice.
Stephan Wilkinson
Old 05-16-2008, 12:29 PM
Noel's Avatar
Old 05-16-2008, 12:34 PM
