Should I buy new pads?
I just put new pads on a stock 89 3.2. (HAwk HP+). Have about 50 miles on them. I was getting a tech inspection for an upcoming DE and found out my rotors are not in spec (to thin). Should I buy new pads since the old ones were already bedded, (is that a word?) to the old rotors or put the slightly used ones back in?
Thanks for your help.
Dave Hunter
89 Carrera 3.2
Old 05-15-2008, 04:51 PM
rnln's Avatar
50 miles? Not even broken in. If you decide to get new pads, give me those. I'll be appreciated
Honestly, I don't know how rich the P guys are and how much they care, but 50 miles pads are brand new to me. I would just keep them with new or old rotors.
Fat butt 911, 1987
Old 05-15-2008, 05:28 PM
ecm911's Avatar
+1 - same pads. I do it all the time on my track car. Try to bed them in before you go on track - or do it on your first run and adjust you driving/speed accordingly.
Earl
78 SC Coupe
93 RSA (Gone)
Old 05-15-2008, 05:33 PM
autovon's Avatar
My mech told me that he often runs new pads without turning the rotors b/c there is more surface area of the pad touching the rotor, and he even runs bedded (you just coined that term, BTW) pads on news rotors b/c the difference is negligible. The key, apparently, is to replace both sides, either front or rear, at the same time. I'm thinking that even the stock brakes are good enough that a novice (which I am) would not even notice. Your call.
'87 Cab
Old 05-15-2008, 08:02 PM
Make Bruins Great Again
Por_sha911's Avatar
Those pads are dangerous! PM me with your address and I'll give you $15 for the set.
Joe
Old 05-16-2008, 02:55 PM
Thanks for the replies. Since I can't decide who should get my pads I think I will just put them back in. Now to see how many more brake lines I can twist getting the calipers off.
Dave
89 911 Carrera
Here is a pic:
Old 05-16-2008, 04:53 PM
Por_sha911's Avatar
Dave, wise choice on the pads. Sweet looking ride you got there.
Joe
Old 05-16-2008, 05:57 PM
