| Registered Join Date: Dec 2001 Location: Cambridge, MA
				Seized motor
			I'm picking up a seized early motor and driving it halfway across the country. Is there any benefit to adding a cup of PB Blaster or diesel or ? to each cylinder down through the stacks, with the hope of 1800 miles of vibration to free it up?
				__________________ Tru6 Restoration & Design | ||
|  05-18-2008, 04:53 PM |
| Registered |
			Its worth a try if nothing else thats less time youll have to soak it later. Iv also heard marvel mystery oil can be good for that
				__________________ 82 SC , 72 914 | ||
|  05-18-2008, 04:59 PM |
| Registered Join Date: Jul 2002 Location: Southern California
			No personal experience, but I've heard that Marvel Mystery Oil or automatic transmission fluid poured into the spark plug holes can help loosen-up a seized motor. I'm sure neither will do any harm, and the fact that you'll be bouncing along for 1,800 miles couldn't hurt either! Good luck, and let us know how it goes.
				__________________ 1984 Targa | ||
|  05-18-2008, 07:30 PM |
| Registered Join Date: Dec 2007 Location: scottsdale az
			i have used the zep product. sprayed on seat rails that stayed wet for 9 months. flood car. that stuff works so well it will loosen a tight mans wallet.
|  05-18-2008, 07:50 PM |
| Registered Join Date: Dec 2005
			I would fill the whole engine with ATF - its a detergent and should help free it up as long as its not seized from excess water getting into it.
|  05-18-2008, 08:49 PM |
| Registered Join Date: Jan 2003 Location: Burford, ON, Canada
			Putting oil down the intake will do little good since most of the intake valves are closed. Pull the spark plugs, fill with lube of choice, insert spark plugs for the trip. NOTE: remove the spark plugs BEFORE trying to rotate the crank. Filling the cylinders with a incompressible fluid means you are hydrolocking the engine. If the engine does rotate later, you will have a mess of oil coming out of the plug holes, so be prepared. What is this engine worth driving 1800 miles for??
				__________________ Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 | ||
|  05-19-2008, 05:29 AM |
| abit off center |
			I don't think I would drive a "seized early motor halfway across the country"
				__________________ ______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. | ||
|  05-19-2008, 06:05 AM |
| Registered Join Date: Feb 2002 Location: Asheville, NC
			Shaun, Where are you picking it up? RE the seizing, I'm not sure I would pour anything down until you determine the cause of the seizing. I assume you are tearing it apart once you get her back to MA.
				__________________ Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C | ||
|  05-19-2008, 10:57 AM |
| Work in Progress |
			When I was looking into doing this someone suggested gibbs penetrating oil: http://getgibbs.com/ Good luck on the trip Shaun and keep us updated. Rich
				__________________ "The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 | ||
|  05-19-2008, 11:40 AM |
| Registered Join Date: Feb 2003
			Why is it seized? Bearings, broken crank, rust in the cylinders? I would disassemble and isolate the problem and go from there. If it's rust in the cylinders I would hone them and rering the pistons, and while your in there...
|  05-19-2008, 11:56 AM |
			Thanks everyone. the motor will be rebuilt from top to bottom at some point. it will never be run as is. it has been sitting in a car in a field for a long time.
|  05-19-2008, 12:09 PM |
				 | Quote:
|  05-19-2008, 12:12 PM |
| Senior Member Join Date: Feb 2000 Location: Lacey, WA. USA
			If it's seized from sitting, then I'd say there's a chance it will loosen up.  My favorite penetrating, rust-dissolving solvent is called Maltby's.
				__________________ Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" | ||
|  05-19-2008, 12:24 PM |
| Registered Join Date: Jan 2002 Location: Long Beach CA, the sewer by the sea.
			Two motors I have dissembled that were seized would not have been healthy if I turned them after getting them loose. The reason is that there was rust inside. That rust would have been picked up by the oil and run thru the rest of the motor, which may have been OK beforehand.
|  05-19-2008, 01:32 PM |
| (the shotguns) Join Date: Feb 2006 Location: Maryland
for the right price i sure would.  i'd love a crapped out 2.2 to take my time rebuilding.  particularly if i didn't have to drop a bunch of $$ to buy it.
				__________________ ***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. | ||
|  05-20-2008, 05:05 AM |
