Transmission Fluid Change
I am planning on changing the transmission fluid soon in my 82 SC.
Any advice as to the minimum height the car should be jacked up to?
Any thoughts on using ramps for the front and then jacking the rear by the engine?
Thanks in advance.
Old 05-18-2008, 05:41 PM
HarryD's Avatar
Here's my story: http://members.rennlist.com/harryd/Trannyoil-Change.htm
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-18-2008, 05:48 PM
Monkey Butt Forespin
84_Carrera's Avatar
Just did it today on my '84 Cab. I went up (3) full "teeth" on a set of ratcheting jack stands, was plenty of "clearance, Clarence (Roger, Roger. What's our Vector, Victor? Sorry, 'Airplane' reference, couldn't help it, it just slipped out)".
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 05-18-2008, 05:53 PM
AutoBahned
RWebb's Avatar
Thanks in advance.
Ramps & jacking on motor are fine, just put stands under there before you get under.
Min. ht. is whatever you need to do the work...
If you measure the drainage carefully, then add just that amount of new fluid, you might get away w/ not having the car level but instead having it nose down.
Old 05-18-2008, 06:17 PM
