LinkBack | Thread Tools | Rate Thread |
(the shotguns)
Argh! Fuel pump running, 3.5psi, replaced needle valve but no fuel in float gauge!
i see fuel in the glass filters, there is fuel in the tank (may have run dry earlier but added more) and pump is doing it's thing. it even registers 3.5 psi at the t before the glass filters (2.4, webers). float gauge is getting nothing though. i don't see anything going on in the filters though. just fuel in there but no bubbles or anything; is this right?
is this possible if the float is cutting fuel off too early? i'd think you'd get at least SOME fuel in the gauge. right?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Bird. It's the word...
FWIW I've purchased a new needle valve that was faulty out of the bag...
John Forcier Current: 68L 2.0 Hotrod - build underway |
PRO Motorsports
Put another shim under the needle seat.
If it takes too many, then you'll need to carefully adjust (bend) the tab on the float that contacts the needle, then fine tune the level with the shims.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
1-6-2-4-3-5-1-6-2-4-3-...
Are you checking all 4 bowls, or just one?
At least one of them should be getting some fuel. Otherwise you've bent all your tabs too much upwards for the shims you have under the needle valves. I'd put a 1mm shim (the default fiber one will do - I think it's 1mm) and set the float tab with the 18mm/13mm setting we said in the other thread. This should fill your float bowls. Blow into the needle valves to see if they're ok (don't get any spit in there ) but I very much doubt all four are bad.
'70 911E Coupe, Webers 40IDA |
(the shotguns)
will pull banjos and run pump to see if i get any fuel at all.
#3 cyl. float bowl is set properly and found this issue when going to #6 float bowl. if fuel i'll set more shims.
"farking Porsche hero"
If you got gas in the filters and the pump's working, it's got to be the needle valves not opening...for whatever reason.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
(the shotguns)
turned on the pump and was so convinced i didn't have fuel going into the carbs i just loosened one of the needle caps.
i've got fuel. turns out the floats were COMPLETELY out of whack. 15 minutes later all 4 are right on. off to walmart to pick up a couple batteries (current batt's are just shot) and will get back in there shortly.
If you haven't left yet go to Costco and pick up some kirkland signature batteries, they are the cheapest and highest rated. They are the premium end of battery made by johnson controls.
(the shotguns)
already got a pair from wally world but will check out Sam's club as well.
actually drove up the street to get gas and did a few loops around the neighborhood. pulls very hard in 2nd and 3rd (didn't get past that). #6 is spitting regardless of mixture adjustment (all others are adjusted per instruction) and my idle is a bit high (1250 or so) but otherwise seems to be working well.
The butterfly farts cannot easily mess up an idle at 1250. It's when you try to keep a 900 that things start going awry
(the shotguns)
900, that's just insanity!!!
![]() thank you all for your help. it is such a good feling to be back in the car again and moving on to projects that can wait for a rainy day while i enjoy the car in nice weather.
BTW, Costco also carries Optima batteries, although their current pricing (since I last looked) isn't as much of a bargain compared to a couple of years ago. Sherwood |
The kirkland batteries are not sealed but why is that so important? Batteries don't just leak unless they are on their side. At least none of mine have ever leaked.
Sherwood |
