Tsunamiboy's Avatar
Restore plastic horn pad?
My SC horn pad is looking faded and the color is uneven. I am installing new leather on the steering wheel and would like to have the whole assembly look new. anyone successfully restored the plastic to a new look?
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 12-15-2008, 09:18 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
couldnt you just soak it in black clothing dye?
i found a nice pad on ebay last year for $20
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 12-16-2008, 09:32 AM
grateful user
don gilbert's Avatar
ill tell u a secret, get some plain old vasoline, smear it all over the plastic and let it sit for a few days. the plastic, which is petrolium based, will soak up the oil out of the vasoline, and when u wipe it off, yea, brand new shiny plastic, u dont have to armour it, it will stay shiny for a long time, the longer u let it sit, the more oil the plasic will absorb, no painting will be required, u can do this on any plastic trim and make it like new.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-16-2008, 12:19 PM
grateful user
see my air box cover, it was so dried and faded it was chalky i let petroleum jelly set on it for a week, looks brand new, and this was about a year ago. thats not armour all or paint, just wiped down
Old 12-16-2008, 02:17 PM
dshepp806's Avatar
If one were to paint it, what would you suggest? A dye (rather?)
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-19-2008, 01:23 PM
i would try the same dye i used for my orange heater control knobs but black. i think the brand was RIT. got it at the local drug store for $2 or something. ide probably boil some up and when not tooo hot, dip the pad in, assuming there are no rips in it...dont want it soaking up water. its a clothing dye
the vasaline trick sounds good too though
1983 911sc
Old 12-19-2008, 01:26 PM
