Oil Pressure/temp Gauge Wiring
I am in the middle of back dating my oil temp gauge to the numeric type.
I have replaced the sending unit at the motor. When I pulled the gauge from the dash I notice a green/white wire not connected. I also notice there is no light for the socket for the red indicator light. Does anyone have the wiring configuration for the back of this gauge (I am hopeless at reading electrical circuit diagrams. It simply looks like a map of the London tube system). Thanks in advance. |
cycling has-been
I did mine in March (77 930).
I'll see if I can find my notes later tonight. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Thanks Bill.
I have the gauge installed and all seems to be working but I have this extra green wire and it looks like it should be connected somewhere. |
cycling has-been
Sorry, I misread your post.
I replaced the fuel/oil level gauge. I have that diagram in my notes if you need it. edit. there is a green w white tracer wire at the 2 o'clock position on the fuel/oil level gauge. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 05-19-2008 at 05:42 PM.. |
