<insert witty title here>
Pics of early (1972) clutch cable attachment - tranny end
Does anyone have a good, clear pic of the tranny end of the clutch cable attachment for an early 915? (i.e. pre-helper spring) When I disconnected mine to drop the engine, it's the one area I forgot to take pictures of, and when I tried to reconnect it yesterday and put load on it through the pedal, I obviously messed it up because the plastic trunion clip thingy broke. Before I do it again I want to make sure I'm doing it right!
Thanks!
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Is this what you're looking for?
72 911 coupe 2.7L S Cams/Webers Street/Track 68 912 coupe 1.6L sold |
or this
plastic breaks, the metal ones rock.
AutoBahned
"early 915? (i.e. pre-helper spring)"
That covers a bunch of wierd attachment methods: 1972-73 -- same pitchfork clutch arm as on the 901 '74 -- ?? '75 -- 90o bend in clutch cable outside of trans. housing, but vertical clutch arm '76, '77 -- vertical clutch arm there are some diagrams that will have me on the threads - Jim Sims posted one I know. Not sure who posted the other. I'll bet no one but Grady knows the whole taxonomy of these things. |
AutoBahned
Should be a boot on the cable where it enters the hole in the pan....can anybody post a PET pic? I gave my PET disc to Evren with the car...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Bingo on the first one! Thanks!
Truer words were never spoken - that's why i'm shopping for a new one. I can't believe the original plastic one held up for so long. But one wrong adjustment with too much tension and SNAP - it's garbage. I've got a threaded boot, too, but I'm not sure where that one goes on - before or after the locking bit. Good thing to know that it's the same as the 901, so I can read up on the adjustment procedure for that. I was trying to work from the 101 Projects write up, which is for a helper spring type clutch. Thanks everyone!
AutoBahned
![]() anybody got a pic of what it should actually look like? I think the one on my car is wrong. |
