-   -   Curious CIS tool on ebay (http://forums.pelicanparts.com/porsche-911-technical-forum/410539-curious-cis-tool-ebay.html)
Scott R 05-21-2008 01:23 PM
Is this possibly for crimping connections on the CIS lines?
http://cgi.ebay.com/ebaymotors/Porsche-tool-P385-CIS-Fuel-Line-Installation-tool_W0QQcmdZViewItemQQcategoryZ35625QQihZ013QQite mZ230254774941QQrdZ1QQsspagenameZWDVW
TRE Cup 05-21-2008 01:28 PM
not for crimping. You place the new cis tubing in this clamp tool and the short exposed end of the tube pushed over the barbed end of the fitting
thanks for posting- i just bid on it. We use this a few times a year and mine grew legs ;)
1982911SCTarga 05-21-2008 02:40 PM
There are instructions and dimensions on how to make that tool in this service manual I have for Volkswagen Rabbits and Sciroccos. I bought the book used for cheap just because it covered CIS and you can never have enough information.
Brian
jcc911 07-07-2008 06:57 AM
Brian, PM sent. Thanks
1982911SCTarga 07-07-2008 07:36 AM
Jeff, I responded to your PM. Others have asked about the instructions to make the tool, and I don't know where my VW Rabbit/Scirroco manual currently is (the wife moved my reference library around).
The "tool" clamps the flexible CIS line, allowing the exposed portion to more easily be pressed onto the CIS fitting. I should think one could easily fabricate this device from two small blocks of steel or aluminum and cutting the clamping grooves with a Dremel tool.
Brian
1982911SCTarga 07-07-2008 07:38 AM
Or take one small metal block and drill a hole just slightly undersize of the CIS line diameter. Then saw the block in half, drill holes for a pair of screws and wingnuts, and voila, the tool.
Brian
Porsche-O-Phile 07-07-2008 08:20 AM
Or just convert over to standard 1/4" fuel hose like every other car in the world uses.
I have a stock of those plastic metric lines, but they were a monumental b1tch to source. Finding stuff for standard size hose is far, far easier.
Don't even try to find braided S.S. metric hose. It doesn't exist.
1982911SCTarga 07-09-2008 06:48 AM
There's a guy on FerrariChat.com who is selling CIS plastic fuel line restoration kits. This thread has pics showing his installation tool (I'm not a member of that BBS, so I can't view the pics).
Brian
yelcab1 07-09-2008 07:35 AM
Brian
Verell is an upstanding member and does excellent work with Ferrari. Highly recommended if anyone is interested.
Danglerb 07-21-2008 07:24 PM
The shop I take my Porsche to is a Goodridge distributor and they have all the stuff for CIS fuel lines in premium hoses. http://www.j2precisionhose.com/
