Broke the driveshaft outer axle...
Broke this part on my -69 911 during a trackday. Luckily the rear caliper held the wheel....
This is the original 69 part, I use aluminum trailing arms from an SC and a G50 gearbox. Is there a stronger part I can use. Would a complete 3.2 G50 driveshaft bolt in? It should, shoudn't it? ![]() Deep inside my spacers.... ![]()
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Racer
Not that I am aware of....the Factory part is quite strong. The hubs are usually the weak point.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
It's a 914 ...
Looks like it failed at the threaded portion. Was there any damage to the threads? There appears to be some rust near the failure area, that could be a stress riser.
I was leaning pretty hard on the left rear and also hit the outside curbs on a few occasions, so I'm not surprised it broke. It could also have been over tightened or maybe the other way, too loose. The hub has issues too, it just pulled out of the bearing with the bearing intact in the control arm. It looked rough. I'll have to check the other side too.
You already have output flanges to match.
'77 S with '78 930 power and a few other things. Last edited by spuggy; 04-04-2023 at 03:39 PM.. Reason: Duh, already has a G50, not an early 915 trans |
PCA Member since 1988
Hmmm. It broke where the nut threads on. That connection should not be subjected to cyclic stress, unless something was too loose or worn. A "stronger part" should not make a difference in this application. I also noticed that the ends of the spline appear to be worn down. What does the outer spline look like? Does the axle spline wiggle around inside the outer spline?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I ordered a set of G50 drive shafts. The threaded part is M22 compared to my old 69 parts that are M20. So they are stronger.
Won't you need to change the output shafts on the transaxle as well?
New hubs are rather expensive. How's the bore on the trailing arm? |
Gee... I didn't know that these could break here... I just learned something new.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
I just talked to an independent Porsche mechanic friend. He had seen this failure on a 996 GT3 RS (with typical mileage of a GT3 RS, not a lot). The drive hub got worn and loose in the bearing, then it broke the same way. New hub 8-900 Euros.... WTF! Time to scan eBay.
Racer
Can you post a photo of the area where the part cracked? The surface that was exposed when the part broke in two....
Edit: Breakage looks fresh.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. Last edited by safe; 04-05-2023 at 02:05 AM.. |
photo of the failure - decided this is a "wear" item . . . Regards, Roy T ![]() ![]()
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
That nut does not take any of the suspension or drive forces. It only retains the CV joint flange and spline in the hub. I'm thinking it was either overtorqued (causing damage and cracking at the nut) or undertorqued, causing it to work around. Or possibly poorly made parts, so that the splines had too much clearance and worked around.
7.0:1 > 11.3:1 > 7.0:1
Like Sboxin pictures show, I've seen a heavily tracked 911 wheel flange break at the bearing collar snout, only without the stub being broken (yet). Pull your wheel flange and remove the outer bearing race then inspect your wheel flange to make sure you don't have a similar failure going on. On the race car, the symptoms appeared as a loose or very worn wheel bearing.
Replace with stock.
Add to list of checking before racing Do not over torque it Keep a couple of complete axles in the trailer, with stub axles |
ahead of the curve
Back in the early days of club racing it was not uncommon for someone in our 3.2 and 3.0 race car group to break the a rear hub. After the first one broke we were always equipped with spare hubs, stub axles, new bearings and the bearing install tool. The tool did not go unused,
Sticky big tires and big spacers increase the loads they see.
19 Carrera T - MPS member 92 C2 SR coupe M491/ 3.8 look- manual 92 C2 SR coupe cobolt blue- manual 73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy 73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
i checked the right side. Looks like the nut has tried to back off.
The left that broke might have done the same but more.
Hi
Really important to torque the stub axle nut to the correct torque using a torque wrench. Also important to install full size split pin. For any racing car I would recommend that the stub axle and hub are crack checked, (MPI) each season. Cheers |
