Carl83911's Avatar
New Starter = Peace of mind...
There was a point where I would hesitate going on a long drive where the car would get pretty hot. After stopping, the car will not re-start. this happened intermittently. Some trips, no problem. other times, I get my monies worth with my jumper cables. Lastly I started carring a portable jumper where I would not have to bother anyone for a jump until one day I needed to use it several times until the spare juice ran out of the jumper.
I finally broke down and replaced my OEM starter to a high-torque and no more starting problems.
Went on a 1k mile trip down the Cali coast last week on vacation and never had the starting problems I once had.
Yipeeekeeeyaayea!!!!!
Thank Jimmy for installing the unit before my trip.
Carl,
Old 05-01-2007, 04:47 PM
on-ramp's Avatar
Same issue on my 83sc... would not start occasionally when the engine was warm or hot. Big pain when driving away over the weekend. .. a new starter solved all problems. one less thing to worry about
Old 05-01-2007, 05:03 PM
randywebb's Avatar
I hope yours works better than mine did. After a couple thousand miles, the pinion gear is all chewed up.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-01-2007, 05:11 PM
New starter is my project for this week. Brand new from autozone $108. with lifetime waranty. If it's a POS and I have to switch it out every year it may not be such a deal. Time will tell.
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 05-01-2007, 05:43 PM
Carl83911's Avatar
You mean the gear on the starter? which HT starter did you use?
Carl,
Old 05-01-2007, 10:14 PM
rnln's Avatar
Re: New Starter = Peace of mind...
I am confused. How can a jumper cable help if your problem is the starter? Jumper cable is only useful if your batery is dead and your starter is in good condition.
Fat butt 911, 1987
Old 05-01-2007, 10:22 PM
rnln's Avatar
I also read somewhere on this board saying HT starter do some damage to the tranny or whatever related.
Fat butt 911, 1987
Old 05-01-2007, 10:23 PM
rnln's Avatar
I heard the solenoid cost $30 only. Please post your feedback with autozone starter, after maybe couple months.
Thanks.
Fat butt 911, 1987
Old 05-01-2007, 10:25 PM
I'll let you know. I don't think you can buy the soleniod alone. Maybe you could have it repaired by a shop,
Ray
Old 05-02-2007, 04:43 AM
randywebb's Avatar
"You mean the gear on the starter? which HT starter did you use?" Yes, the pinion gear is on the starter. I used the one that Pelican sells. Not yet sure why the problem exists, but the starter is almost brand new...
- BTW, an elec. shop can probably put a new solenoid on your unit. Find one that does work for German cars.
Old 05-02-2007, 11:38 AM
My current starter has been in there for eons. I think it might be the same part used on some VW bugs. I have a high torque starter waiting when I pull the engine for some future cam replacement.
At any rate, the Bosch solenoids are nothing unusual. Like Randy suggests, an electrical shop could be a source.
Sherwood
Old 05-02-2007, 11:59 AM
Carl83911's Avatar
Re: Re: New Starter = Peace of mind...
The Starter selonoid is the culprit. after a couple of decades, the selonoid gets a bit tired from all the heat coming from the heat exchangers which results in more resistance. so when it gets hot, the selonoid refuses to kick on to activate the starter. An extra boost from a jump sometimes helps.
Carl,
Old 05-02-2007, 04:21 PM
So what is the solution when I need a new starter? Does anyone have experience with the lighter weight starter sold at Pelican?
Old 05-02-2007, 05:48 PM
The options:
New starter from PAG
New starter from ?
Rebuilt starter
Rebuild your own starter
Previously-owned starter
Hi torque starter
RE: the HT starter. I purchased mine from eBay. The working guts are rebuilt/remanufactured and installed in a new hi-torque housing. There is probably a version (Pelican?) that contains all new components.
Starters are pretty low-tech and should last a long time. They only operate for a couple of seconds at a time, maybe only a total of a few hours use spanning several years.
Sherwood
Old 05-02-2007, 11:56 PM
So the starter on the engine/trans I just removed from my car and which was working when removed should be left on? Of course I realize this is a question without a definitive answer but I am just trying to decide what to do. Replacing the starter before I re-install the engine would be alot easier than once everything is back together.
Tom
Old 05-03-2007, 08:55 AM
Tom
I agree with your last sentence, but replacing the starter on the vehicle is not impossible, just not as easy with the engine removed.
Sherwood
Old 05-03-2007, 12:09 PM
Hell Belcho
Nostril Cheese's Avatar
on my Carerra, I disassembled the solenoid and cleaned up the contacts inside. The repeated arcing over the years builds up corrosion. Havent had the problem since.
Old 05-03-2007, 12:17 PM
rnln's Avatar
I am getting ALL CONFUSED now. I have read this thread over and over couple months ago and decided to replace my old starter, with a rebuilt unit. It lasted several months and now it happend again, occationally. Am I just in bad luck, so I should come back and ask for another one? It's still under waranty. Or if this model of starter is a bad design from start, I should dissect it and clean it up myself?
Another question, which part is the problem? The starter itself (bigger piece), or the solenoid piece?
I read someone took it apart and machine (grind) the inside of the housing to make it bigger. Anyone know about this?
Fat butt 911, 1987
Old 07-24-2007, 11:52 PM
Bringing this thread back form last year. My "good deal" autozone starter acting up again. It intermittantly starts-other times just clicks. Seems to do better with fresh charge on battery or sometimes i can make if work if I simply clean the battery terminals. I've triple checked and cleaned all grounds (including tranny). I spoke with a local race shop owner who immediately asked if the starter was a remanufactured unit. He said that is where the problem probably is because of the half-a$$ed way they are rebuilt. He suggested a brand new unit. Any thoughts and Bosch OEM new ($$) versus high torque versus reman. Thanks is advance.
Ray
Old 05-27-2008, 06:17 AM
rnln's Avatar
Rebuilt unit has premature problem is normal to any car, but in our car, many people include myself found that the signal wire from ign key to the starter (yellow wire) has intermediate problem.
When your won't start, can you measure the voltage at this wire while trying to crank? Mine said around 7v while it showed 11v when it works normal.
Fat butt 911, 1987
Old 05-27-2008, 09:35 AM
