-   -   How long does brake fluid keep in its container? (http://forums.pelicanparts.com/porsche-911-technical-forum/410841-how-long-does-brake-fluid-keep-its-container.html)
jcunning 05-23-2008 06:36 AM
I bought a litre of ATE super blue fluid about 4 years ago and completely flushed out my brake system. I still have about 1/3 of a container left.
Is this stuff still good because of the metal container or should I just recycle it at this point?
Obviously fluid in metal is better than plastic, but does anyone have any rules of thumb for how long it can be used after it has been opened?
I probably have 5 or 6 different bottles of fluid in my garage because I just buy new stuff all of the time and just leave the left over in the container forever...
Bill Verburg 05-23-2008 06:40 AM
recycle anything that's been opened for more than a few months, if you live in the desert longer by the coast shorter
hcoles 05-23-2008 06:56 AM
it would seem ok to use after a long time... assuming it was open for a total of 5 minutes during various fluid fill operations.. and then closed tight in a metal can..
Yes, it was exposed to air with some humidity for a short period so it did absorb some water.. but I'm guessing not very much.. I'm not a brake fluid expert just commenting.. because I have various cans around the garage also. Could be that the "exposed" fluid should be used in street cars and not for track.
red63 05-23-2008 07:31 AM
If you are just topping off then it would seem low risk. If you are doing a full flush why not spend a few dollars to be sure. If you flush your system every two years it seems to me that you don't want to use stuff that is more than two years old.
cgarr 05-23-2008 07:40 AM
Isn't the MC reservoir vented?
hcoles 05-23-2008 07:40 AM
that makes sense.. if you're going to all the trouble to flush the brakes... why not just use new fluid... but these cans of fluid build up in the garage and we don't like throwing stuff away.. I need to make a recycling run... I have all sorts of containers on the side of the house. Brake fluid, trans oil, coolant. My garbage company will take engine oil but that's it.
hcoles 05-23-2008 07:41 AM
cgarr,
I was thinking the same thing.... vented = the air on top of the fluid has moisture right?
Zeke 05-23-2008 07:53 AM
On more thing: If the container is full or nearly full, then the amount of air containing moisture is minimal. I wouldn't keep half full containers around too long.
Esel Mann 05-23-2008 10:06 AM
From your description it would sound like you need to discard the brake fluid and use new brake fluid. Also, if the car is being tracked, where high brake temps are likely, I have yet to see anyone use opened brake fluid. The general rule of when in doubt use fresh fluids seems timely as well.
That being said, since there have been no references to source information/data on such (mine included) why not ask the source? Consider going to ATE North Americas homepage www.ate-na.com for contact info. Ask them what the shelf life of their fluid is after being opened and any data they have to support their claim.
Regards,
Carlton
Sunroof 05-23-2008 10:28 AM
Brake fluid is hygroscopic and takes up moisture very quickly. The moisture seems to settle in the brake caliper where rust will form over time and create a major problem. No one can really determine shelf life without measuring humidity and storage conditions. I would feel better storing brake fluid in a garage in Scottsdale, Arizona then here in Atlanta, Georgia! :(
Porsche brakes are legendary, we all drive our cars harder then others and depend heavily on a sound braking system. Bleeding 911 brakes, at least on an older 911 (1973.5T) is quite easy, so I try and bleed the system at least once a year if not more!
With that, using a can of Racing Blue fluid is well worth the peace of mind and price to ensure my brakes hydraulics are in top shape.
Bob
73.5T, in Sepia :cool:
jhelgesen 05-23-2008 10:50 AM
I write on the outside of a brake fluid container the date I open it. Won't use one more than 3 months old after its been opened.
RWebb 05-23-2008 12:55 PM
I agree re the air space, but note also that the closure, once breached can never be perfect again. Also, he has a big air space in the can.
Do what Bill said - how many pennies are we talking about here??
Also, discard does not mean toss in trash. Brake fluid is hazardous waste. Take it to an auto parts store, or Quikie Lube - they'll put in the right haz. waste recycle can for you. Or take it to your county or city transfer station for the same thing.
DRACO A5OG 05-23-2008 01:07 PM
Can't one vacumm seal it to keep moisture out?
RWebb 05-23-2008 01:16 PM
yes, if you trust the seal.
We've had all sorts of problems with Oxygen migration into or out of supposed perfect tubing runs while doing weird things to baby birds and mammals. We finally tore out everything and went with stainless steel tubing for most of it. Could have been the cheap labor (grad. students) not the material. Also, oxygen is not water vapor, but ...
KIS and toss the brake fluid for recycling.
hcoles 05-23-2008 01:16 PM
not sure if we need to go on and on with this... I don't advocate using old bf. ... but
I assume open for 5 mins. seal.. this means no more moisture goes in the fluid because the cap is sealed closed. So I think what we are comparing is:
1 - new un opened brake fluid
to
2 - brake fluid that has been opened and then quickly closed/resealed. This causes x grains of water vapor to get trapped in the can.. this then gets absorbed into the bf. From what I read Dot 3,4 fluid is designed to put the water in suspension and evenly distributed. It does not go somewhere and pool as a rule. Dot 5 does tend to pool easier.
if we don't think putting the cap back on tight seals the can then of course all bets are off..
JeremyD 05-23-2008 01:24 PM
I use the blue (old can) for flushing - I'll let the MC container get down low (pump the existing out) - then pump some blue through there - let a couple of pumps in each caliper. Then flush normally for my DE prep. Then I know that when I have worked the "blue" through the system that I'm working of fresh fluid.
In Florida - I tend to bleed the brakes closer and closer to my drive time - my mechanic recommended no more than 48 hours before an event because of so much inherient moisture in the air.
911pcars 05-23-2008 02:47 PM
True Randy, but why dispose if it's still useable? On a partially filled can, insert marbles or ball bearings to displace the air, then seal the can and put it in a HD zip lock bag. Why dump good BF if it costs $75/liter or even $10/liter?
People in the US waste and use up more resources than anywhere in the world.
Sherwood
rusnak 05-23-2008 03:47 PM
I do something similar. I use the "old" brake fluid for brake bleeding after I have broken the brake lines. Then use the pristine unopened can of fluid to do the final flush and end up with all new fluid. Why use good fluid to perform a brake bleeding? I know, I'm a cheap bastiche.
RWebb 05-23-2008 04:32 PM
That should help a lot Sherwood, and I do appreciate the thrust of your comment.
I will bet a lot more is wasted by people changing their fluid every few months in LA ("before every D.E.") than by this however...
gregwils 05-23-2008 06:38 PM
What about an unopened can
I have an unopened (still sealed) can in my garage of ATE blue, I would guess it is close to five years old. Is it still good?
Green 912 05-23-2008 06:57 PM
I have a true fluid boil point tester and I have been testing a partly used up can of ATE blue from time to time. In going on 7 years it has lost 5 deg boil point. That is about 1%. This can is partly filled and stored in humid condition in the summer.
Green 912 05-23-2008 06:58 PM
It will cause you cars brakes to explode! Send it to me ASAP and be saved. :rolleyes:
Thrlls 05-23-2008 08:46 PM
I flush my brake system once a year, and alternate between ate blue & gold. I use the entire can to flush the system just to be sure the fluid has been exchanged. At $15 a year, this is worth the insurance of having good brakes. I then dump the old fluid into an oil change box to be absorbed and place the box in the trash can.
If I ever have a need to top off the mc, then I have another problem...a leak somewhere, and will need to fix it. So I see no need to store brake fluid for any length of time. The less HM I have stored at my home the better.
RWebb 05-23-2008 11:33 PM
- Good to know! Va. is not the driest state in the union, either. Is it in a heated area in the winter?
911pcars 05-23-2008 11:53 PM
FWIW, some brake fluids absorb moisture faster than others. As a consequence, their wet boiling point ratings are lower, as much as 100ºF difference. These particular fluids will have poorer shelf life in partially used containers. You can compare some HD fluids on this chart:
http://www.seinesystems.com/BrakeFluids.htm
Sherwood
Wayne 962 05-24-2008 12:16 AM
I'm not sure how much of this is urban myth versus actually affecting performance. Tony Callas and I had this discussion recently, and we couldn't come to a definite conclusion. We did decide that brake fluid was cheap enough to go the safe route and use new stuff every time. Don't forget that the fluid sits in your reservoir for years at a time - is that to say that the stuff in there is no good? Still probably safest to use new fluid (plus more brake fluid sales for me!) :)
-Wayne
Bill Verburg 05-24-2008 04:58 AM
I mwouldn't keep fluid in my street car longer than 2yrs, the damage that can be done from trying to extend b/f life is massive and expensive especilly since abs pumps became common
for tracked cars most organizations mandate at a very minimum annual b/f replacement, those cars inflicted w/ undersized brakes that run hotter than desireable will usually need fresh fluid for each event(if not sooner)
It's your money and your car, but it's a shame to see so many misers around, like the o;ld ad says"Pay me now or pay me(more) later"
javadog 05-24-2008 05:12 AM
If you ever boil your brake fluid at a track event (or elsewhere) you'll be an instant believer, that I will guaruntee.
Also, anybody that thinks that Bill is kidding about the damage to hydraulic system components from water contamination of the fluid is invited to spend the summer in Tulsa, rebuilding a bunch of motorcycles I have aquired. ALL of them have issues related to old, contaminated fluid.
Those of you with the new-fangled hydraulic clutches need to bleed those systems too.
JR
ossiblue 05-24-2008 07:30 AM
I use this rule of thumb: I change the fluid every two years in the system, and any remaining fluid in the can is kept only that long also--saved only for top-off's (rare) and then desposed of.
Definite, heed javadog's post, above.
RWebb 05-24-2008 02:07 PM
"massive and expensive" means you may have to replace all the metal lines, and each caliper.
I am a strict 2 year person on my car (street use). Everybody gets to make their own choice.
hcoles 05-24-2008 02:55 PM
yes, for older cars I like to do every year.. come to think of it.. all my cars are old... I now have a full time job maintaining 5 cars.
