Tsunamiboy's Avatar
Parking light contact?
While chasing an electrical short in the left rear parking light (only?) I am a bit perplexed about what the PARKING LIGHT CONTACT is? It is shown on the exterior lights diagram??? Is that a devise, connector or ???
I have found grey wires with black stripe melted between the fuse block and the light switch but still looking for the source of the short
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 05-23-2008, 11:24 PM
Only a guess, but that may be the contact in the turn indicator stalk, on the steering column--it turns on the parking light for a particular side, only when the ignition is off.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-24-2008, 07:33 AM
aj88cab's Avatar
That is exactly what it is. Many European cars have this feature. It is provided for parking on narrow city streets as are typically found in Europe.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-24-2008, 10:49 AM
Tsunamiboy's Avatar
Thanks gents! You are spot on! I have used that feature when parking on narrow streets. Now to continue the chase to find the source of the short.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 05-24-2008, 03:19 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
Just another idea, have you done any work on any of the lights, I replaced a tail light body and the weight of the unit while hanging there pulled one of the spade connector contacts upward so when I reinstalled the back plate it ended up touching the metal body and causing the short. Just some thing to think about as I chased it for days before I realized what an idiot I was for not checking there first.
JANZ
Old 05-24-2008, 07:37 PM
