Fuel system question
I have been searching but can not seem to find what i am looking for...Inside the passenger rear wheel well there is a canister with two fuel lines attached. I am in the process of replacing all of the fuel lines, just wondering what this canister is...?
Expansion and evaporation are up front...so this is....?
Seems to have taken a beating from tire "sling" exposure, rust, crud, etc...
Help appreciated
86 911 Targa
Old 05-23-2008, 07:16 PM
Charcoal canister used to hold the fuel vapour until the car is running, IMHO keep it, is good for the car, you and the environment.
LM
83 SC
Old 05-23-2008, 07:53 PM
Thanks! I pulled it out and cleaned it up, hoses, clamps, etc. Amazing how much crud is pinned in so many areas...
86 911 Targa
Old 05-24-2008, 09:03 AM
AutoBahned
RWebb's Avatar
if the hoses are hard & brown then they are due to be replaced with fuel vapor rated hose
search on emissions + [charcoal .or. canister] for much more info
Old 05-24-2008, 02:03 PM
Tim, that is vac hose, not fuel hose. It is much cheaper than fuel hose and available locally.
Old 05-24-2008, 04:35 PM
I replaced all of the fuel hose and a fair amount of vacuum and vapor and w/washer hoses.
After pulling the canister in the rear and the overflow / washer resevoir up front, i probably dropped 2 pounds of dirt and crud that had built up over the years. I just kept replacing any hose i encountered...most were ok, but there were some dry and cracked lines that were long overdue.
Thanks for all of the help!
86 911 Targa
Old 05-24-2008, 05:44 PM
AutoBahned
RWebb's Avatar
good work!
Old 05-24-2008, 06:11 PM
