CDI/Fuel issue ('77 911s)
Hi everyone,
After getting the car running again after an engine-out clutch replacement, it ran perfectly for about 3 weeks and now the car simply won't start. I have checked and there is spark at the spark plug end No fuel coming from injector when I crank the car though but the injector end was wet with fuel when I removed it to check No whine from the Permatune CDI.... No fuel pump noise either Checked all fuses, all OK (repaced the two fuses in the engine compartment just to be sure) One of the cables in the CDI loom was a bit melted but it is intact so that may just be a function of age and exposure to heat in the engine compartment Cabnnot find any relays or the like under the driver's seat Have CRC'd the various electrical components ![]() ![]() ![]()
Permatunes do not whine like a Bosch CDI..you will need to take the air filter top off and lift up the air sensor plate to get fuel..Have you checked the fuel pump relay in the front trunk? (the red one)
Check for fuel flow:
1-Remove air Filter; 2-Put key in RUN position; 3-Slightly lift the air flow sensor arm inhte air box and if youhave fuel flow, you will hear a buzz/whine from the injectors. Check Ignition: This thread may be helpful: Ignition problem troubleshooting (electrical)...... Also, from another thread (How do i check a coil with a timing light?? Quote:
Hi, checked for fuel flow and no, there's no whine from the injectors..... There was a little resistance the first time I lifted the airflow sensor but no noise at all from the injectors......
You may have a clogged fuel filter, clogged screen in your tank or a dead fuel pump.
Remove the line from the fuel pump that feeds the accumulator in the trunk. Get some line to direct the flow out of the engine room. disconnect the power to the CDI Box and put the car in run. See if any fuel gets pumped out.
repleaced the red fuel pump relay and hey presto.... all running again. Thanks for the advice team....
