Rear Fog Lights wiring...
Hi,
does anyone know how to wire up the rear fog lights and relay? which wire goes to what fuse? the only one that i'm sure of is the green/white on Fuse #1. Thanks! |
at the relay I have following:
#30: Red #85: Blue/White; goes to the fog light switch #86: White #87: Green/White Grey wire, coming from the light switch. So I think: Red -> fuse box #17 Green/White -> fuse box #1 This leaves me with a Grey(Switch) and a White wire(86) Where do they go? PS, only have rear fog lights. Thanks! |
What car?
I had to add, because some have only one light located on the rear roll pan or valance, while others have two lights mounted in rear center panel.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... Last edited by 3.2 CAB; 05-25-2008 at 03:31 PM.. |
Hi,
German '74 911S with 2 rear fog lights ![]() Greetings |
