joetiii's Avatar
radio removal
Whats the trick to removing a factory radio in a 69?
Special tools required?
joe
'69 911 E Targa - aka "RoxiE"
Old 05-23-2008, 09:00 AM
What's the radio?
Does it have 2 holes vertically on each end? If so, you need a tool (or you can bend pieces of a coat hanger into a 'u', push them into the holes and it should pull out).
Old 05-23-2008, 10:22 AM
Disconnect all wires and antenna cable. Check for a rear mount bracket and disconnect. Carefully removed coverplate. Use screwdriver to depress clips on the front corners that hold radio to dash. Pull radio out from the front of the dash towards the inside of the car.
Rob
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 05-24-2008, 09:45 AM
poorsha's Avatar
Just grab a big old screwdriver and pry it out.
That's what some ahole did to my 72 back in 1980.
It's OK though cause I caught him.
Something he will remember everytime he brushes his teeth
Old 05-24-2008, 09:51 AM
Joe, why are you removing the factory radio? If you're replacing a good working radio, I'd be interested in buying it, cus my Frankfort has quit on me.
Rob
356robo
70 T Targa
Old 05-24-2008, 09:59 AM
If it's a FRANKFURT, they're worth something.
They can often be repaired for not too much coin.
And they don't have the holes on the sides.
Old 05-24-2008, 01:51 PM
joetiii's Avatar
Rob
I have installed XM so I no longer need/use. It got static through the blown front speaker last time it was hooked up. How do I tell if its Franfurt radio?
Wil get under dash soon.
j
joe
Old 05-26-2008, 06:25 PM
Easy way.
Search ebay "Blaupunkt Frankfurt"
See if it matches the pics - there are several on ebay.
Old 05-26-2008, 06:59 PM
