Half Shaft Rebuild-73 911T
Doing a rebuild of 73 911T half shafts
How do I get the ends off of the shaft?
Not looking for opinions-only people who have actual experience(and grease under their finger nails)
Jon
Old 05-27-2008, 08:28 PM
stevie 77 930's Avatar
there is more in this post than you need but you'll see a "c" clip on the end of the shaft in a couple of the pictures. You'll need a C cllip pliers to remove it. The shaft may need some help of a rubber mallet or brass hammer and piece of wood. do not use a regular hammer directly on the shaft. there you have it....
Carrera CV Boot Replacement
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 05-27-2008, 08:55 PM
barney911rs's Avatar
After the clip is off, I've used a brass drift to persuade it off. Be very careful not to hit anything other then the small inner race that is splined to the axle shaft. That is a good thread Steve referred you to, but on your car you should be able to unbolt the CV from both ends, and leave the stub axle in the hub. Here is the parts diagram
https://techinfo.porsche.com/techinfo/pdf/en/catalogues/E_911_73_KATALOG.pdf
You can then clean and re-pack the grease on both ends.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 05-27-2008, 09:34 PM
