Wildman Emeritus
Run Then Stall
Ok, I need some ideas.
It starts, runs to about 3000 and then just stalls in about 10 seconds or so. My sense is that it is running on the spurt from the cold start valve and not getting fuel enough to continue running. I pulled the coil wire and an injector and it seems to be spraying fuel as I could see fuel spraying into the jar. I am fresh out of ideas.
It ran before I replaced the fuel filter, injector seals & O rings, runner gaskets & hoses and a fuel line over the winter.
Any help will be greatly appreciated or I am just going to have it flat bedded off as I can't take much more frustration.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-27-2008, 05:43 AM
do you have a 911 SC running with cis injection by chance? If so, check your distributor advance and vacuum leaks. I'd bet on a vacuum leak somewhere, but need more info on your car.
Old 05-27-2008, 08:30 AM
IROC's Avatar
It won't run on the cold start valve "spurt" alone. Unless you're getting around 3.3 bar (? from memory) the fuel injectors won't even open and it wouldn't even start and run. Are you seeing fuel sprayed into the jar for more than 10 seconds?
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-27-2008, 08:34 AM
Wildman Emeritus
I will have to do another check on how long the spray continues as I didn't time it yesterday. I will do so tonight.
3.0 Liter With CIS.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-27-2008, 08:40 AM
