adhesive for weatherstripping?
What adhesives should I use for weatherstripping and carpet? I know there probably isn't one adhesive that would do both so I am looking for the best in each application.
Thanks, Bob |
3M adhesive #08001 from our host will do it all.
Scott '86 911 Carrera Coupe, PCA, PBC |
One is a contact cement and the other is sort of a contact cement. On the rubber, you want to be able to reposition at least once. I think the 3M brush on, or tube applied is the best. For carpet, I seem to prefer the Permatex version in the spray can. Both give you a little time to work things out.
Pelican also carries Wurth products that are tailored to each of these jobs. The black rubber cement looks interesting to me although I have no direct experience with it. |
I've used the 3M tube stuff with good results (hood and door seals).
Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Less brakes, more gas!
I just used the Permatex stuff today on my other car... worked very well on the hood seal I was working on.
for carpet I was always told to use 3M for the best results. -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I used 3M Weatherstrip Adhesive earlier this month to replace a door seal, and it turned out really nice.
I've used another 3M product for upholstery, which was a spray on, like Milt says. It worked much better than brush on contact cement, which went on way too goopy and thick. Either way, it is a good idea if you are going to be doing the whole car to buy a white deadblow hammer, or rubber mallet. The white one is softer and made of rubber vs. a plastic one, which might be too much. The rubber mallet will help you to make positive contact between the carpet and the glue without crushing the nap. |
I like GOOP. sticks like crazy to rubber.
A local upholstery shop that I use prefers DAP contact cement for carpet. There are two kinds, water-based and solvent-based. He suggests the solvent-based version.
JR |
