Front suspension pan early 911
Does the front suspension pan have the front gas tank support welded to it or does it have to be purchased separately?
Thanks! |
The gas tank support is seperate, but can be puchased as part of a suspension pan replacement set.
Its not welded before delivery because: A. it will be difficult to fit. B. You need to weld on the supplied reinforcement plates onto the a-arm bolt locators. This needs to be done before enclosing that area with the gas tank support. Hope that helps |
Helps a lot. Now I know what direction I'm going to take.
Thanks for the reply Jury. Much appreciated. |
Careful, most of these kits don't include the re-inforcements
Robert Currently Porsche less (but the wife has 2) |
