-   -   Need help with brake problem (http://forums.pelicanparts.com/porsche-911-technical-forum/411636-need-help-brake-problem.html)
ttw18 05-27-2008 06:09 PM
Hello, finally got my project on the road (pics to follow soon). I have taken a few short shake down trips and have encountered a brake problem.
Here is some info: per previous owner
rebuilt M calipers
new master cylinder
new pads, fluid etc.
Here is what happened:
When I went on a longer trip and the brakes heated up more, they began to gradually bind until the car was unmovable. When I came back to get the car and they had cooled off and I was able to drive it again.
So I:
Had to hammer off the front caliper
Removed the calipers to inspect and the piston moves freely.
Noticed pins centering pads had no grease.
My theory:
The pins prevented the pads from retracting as things started to heat up and expand. This explains why they were able to work again when they cooled off.
Any thoughts?
rllevin 05-27-2008 07:48 PM
Old rubber brake lines preventing return of fluid from pistons?
ttw18 05-27-2008 08:14 PM
nope new brake lines.
DRACO A5OG 05-27-2008 08:22 PM
Are you absolutely certain the Spring is placed properly?
It sounds like the springs are not puting enough tension on the pads to keep them away from your rotors when pressure is released.
Placing anti sieze on the pins and spring where the back top of the pads meet the spring is a must but even if you forgot or did not have the antisieze the spring (if clean) should give enough tension to move the pads out when pressure is released.
my 2 cents
ttw18 05-27-2008 08:51 PM
The spring was installed correctly as far as I could tell. Still confused as to why the calipers/pads not relasing when hot.
Flieger 05-27-2008 08:56 PM
I know you said new flex lines, but it sure sounds like swollen rubber flex lines to me.
DRACO A5OG 05-27-2008 09:02 PM
How about some pics Brother?
barney911rs 05-27-2008 09:10 PM
Both fronts were stuck or just one? I agree with Flieger, it does sound like bad lines. Get some new OEM rubber lines and see if the problem goes away. One way to test this, is when they are "stuck" crack open the bleeder and see if that releases the pressure and the pads will retract. Be careful not to spray the fluid on hot brake parts, as it could catch fire.
ttw18 05-27-2008 09:36 PM
2 more things to add:
Seemed like driver front caliper was the hottest.
The pedal became stiff when brakes started to bind.
rusnak 05-27-2008 10:07 PM
do you by chance use a motiv pressure brake bleeder?
ttw18 05-27-2008 10:14 PM
I have one, yes. I have not used it on this car yet.
Flieger 05-27-2008 10:15 PM
Just throwing this out there:
Knock-back pin mechanism binding when warm?
rusnak 05-27-2008 10:46 PM
I was thinking maybe the vent tube is still clamped or pinched in some way.
ttw18 05-27-2008 11:04 PM
Flieger - Not sure what you mean "knock back pin" I am coming from a bmw background; same language, different terminology
Rusnak- vent tube? are you talking about the motiv?
Keep it coming guys! I appreciate it. I think it is the last thing keeping my car off the road.
rusnak 05-27-2008 11:12 PM
no, the master cylinder reservoir vent tube. Crazy theory, probably far fetched, but what if someone forgot to release the tube clamp, and the brake fluid got hot, and the air in the reservoir started to expand?
Flieger 05-27-2008 11:32 PM
I posted here before rusnak but it didn't work.
I have a tube that goes from my fluid tank vent through the smugglers' box and out the bottom of the car. Now the trunk is not wet anymore and there is blue fluid in the lines and on the ground. I guess I just go too fast:D. I don't have any interior in the cabin or trunk but it keeps the paint from melting.
The knock-back mechanism is a pin in inside the cylinder bore mounted to the outside cover of the caliper body. The piston has a tube protrusion with a brass tube and a spring that grabs the pin and lightly forces the piston back toward the rotor. This makes the piston react quicker and build up pressure faster:
http://www.early911sregistry.org/forum/showthread.php?t=17846
I know these are S calipers but Ms have them too. See the M caliper thread: http://www.early911sregistry.org/forum/showthread.php?t=16254
If something is expanding when warm and binding, it may not allow the piston pressure to relax.
Just a thought.
ttw18 05-28-2008 01:11 AM
I think I made a mistake. The calipers are on my '67. I thought they were called
M, I was wrong.
Flieger 05-28-2008 11:13 AM
L calipers?
http://www.early911sregistry.org/forum/showthread.php?t=20424
barney911rs 05-28-2008 04:23 PM
on a 67, that eliminates a brake boster problem, so the clogged MC vent is very possible. That's why I suggested cracking open the bleeder next time it's stuck. If the pads release, it's not a caliper problem.
ttw18 05-29-2008 12:52 PM
Thanks guys,
I am going to check the MC vent line this weekend. I also am going to replace the rear lines as they may be old contrary to my previous belief. The previous owner may have only replaced the fronts.
