-   -   Let's see your twistie and speed run video (http://forums.pelicanparts.com/porsche-911-technical-forum/411739-lets-see-your-twistie-speed-run-video.html)
RarlyL8 05-30-2008 06:14 AM
Yes, this speed differentiation even frightens me.
http://www.race2ube.com/view_video.php?viewkey=99fe63f3e0041f02638a
x98boardwell 05-31-2008 12:18 PM
You Wont Believe this!!! (Porsche, Supra and VW)
One Crazy VW Rabbit GTI from the early 80's.... with one very large Turbo. I'm sure it barely goes at low speeds.
http://www.youtube.com/watch?v=XfnOseO1-wk
Have fun with this one.
Bry
Flieger 05-31-2008 05:02 PM
Vee Dub; German Ingeneering in die Haus, Ja! :D
Todd Simpson 05-31-2008 05:21 PM
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/Vf47CRPQmfI&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Vf47CRPQmfI&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
75Carrera 05-31-2008 07:54 PM
SWEET TURN TODD!!! Is that you? Very nice...
Flieger 05-31-2008 08:44 PM
Where is that? Look like a nice track
TimT 05-31-2008 09:18 PM
Watkins Glen..... Todds vid looks like after the bus stop
One of my vids from Watkins Glen
http://www.rudtnersracing.com/Videos/WGI05.wmv
TimT 05-31-2008 09:26 PM
Edit:
That is the toe, after that is the off camber left, then the fast left
75Carrera 05-31-2008 09:29 PM
Some excellent stuff! Thanks TimT Outstanding power and driving. What's the car look like? Keep em coming guys
Flieger 05-31-2008 10:02 PM
TimT,
:eek:WOW!
You were flying!:D Wucha got in that thing? I must see photos. That engine was just screaming!
Thanks for the video
Flieger 05-31-2008 10:25 PM
I went to the web site and saw the other great videos of the Watkins Glen Club Race. That track is nice with the medium tight turns and fast sweeps and all the nice elevation change. The green grass and trees is nice, too. I like to see grass next to asphalt instead of that ugly run-off area. Like der Gruen Holle,:D
Is the car that 935 on the web page? Can you give some technical specs?:cool:
ted 06-01-2008 07:09 AM
Couple vids, on twisty SOW.
3 street legal widebody 300hp 3.6 widebodys.
All around 2300lbs.
http://i148.photobucket.com/albums/s...ErikSOWpt2.jpg
http://i148.photobucket.com/albums/s...dSOW_0001a.jpg
http://i148.photobucket.com/albums/s..._MikeatSOW.jpg
Goof off version.
http://i148.photobucket.com/albums/s...OWeveryone.jpg
One of good lap at Buttonwillow, same street legal green and white car.
http://i148.photobucket.com/albums/s...owtimedlap.jpg
Like a dog chasing cars at Buttonwillow,
http://i148.photobucket.com/albums/s...s59BlueRSR.jpg
http://i148.photobucket.com/albums/s...th_Dons935.jpg
Quicksilver 06-01-2008 08:00 AM
http://www.youtube.com/watch?v=wcdOjVnRKBs
This is just quick entertainment :p
I agree that RarlyL8's wins the pucker factor award...
It also provided a link to this video too:
http://www.race2ube.com/view_video.php?viewkey=dfdc2b83477cd76dee98
Oh, and the guys in the 2nd video from Milt really got what they were asking for. I really enjoy driving at extra legal speeds but I NEVER pass blind or use both sides of the road unless you can see quite a ways ahead. Stupidity should be its own reward...
wcc 06-01-2008 10:09 AM
The camera is on my old '85 911 filming a couple 930's following me.
http://youtube.com/watch?v=VwwAPkoc5WE
75Carrera 06-02-2008 02:06 PM
One more short twistie section
http://www.youtube.com/watch?v=YTl3R-1hmn0
TimT 06-02-2008 07:16 PM
Yes it the car on the opening page of the site. Basically it is a 935 we built out of a '79 930 tub. It has a 3.8l, Haltech EFI, 12 injectors, cams ground to our specs, 800 or so HP. Crank is center drilled, main bearing modified, rod journals reground to 2 in using clevite nascar bearings, custom pauter rods.Regeared G50 box, and all the other go fast bits as needed.
Flieger 06-02-2008 09:31 PM
Nice:D
When you say "Crank is center drilled" do you mean also that the oil is fed through the center of the crank like on the 912 engine from the 917? I thought that this was only do-able on the 917 because of the central power take-off. The flywheel, clutch, and other stuff was too hard to work around on a 911 I thought.
TimT 06-03-2008 12:03 AM
Probably a better term is cross drilled. We have the crank drilled at the center journal so the drilling passes through the existing oil passage. The bearing is then put in a fixture and grooved. All this gets more oil to the two and five rod journals. With these mods and the Ti valve train components the engine turns to about 9000 rpm. Usually shifting at 8800 in races.
75Carrera 06-03-2008 07:19 AM
My count was 83+ turns in this sweet section ( 9 minutes) That's an average of a turn about every 6.5 seconds. Who's got some video with even more twisties than that to share?
http://www.youtube.com/watch?v=MfIp-5iDuic
ted 06-03-2008 07:31 AM
the ultimate twisty video?
http://video.google.com/videoplay?docid=6184680728064832823
