-   -   rattley window (http://forums.pelicanparts.com/porsche-911-technical-forum/411847-rattley-window.html)
ramonesfreak 05-28-2008 06:18 PM
rattley window
when my driver side window is about half way up, it rattles a bit over small bumps. is there something i can adjust or is it something i have to live with? thanks
group911@aol.co 05-29-2008 05:56 AM
My guess would be the bracket the secures the main post has broken. The main post is the part that divides the vent window from the main window. At the bottom of that, inside the door is a bracket that often breaks and rattles.
You need to pull the door panel and look inside the speaker hole to find it. Takes an allen wrench to pull it.
ramonesfreak 05-29-2008 06:01 AM
thanks. ill check that out. but note: i dont hear anything rattling inside the door. the window itself, as it sits half way up, rattles a little. like its isnt sitting tightly
javadog 05-29-2008 06:14 AM
Take a look at the window channels. I suspect some of the felt is missing.
JR
ramonesfreak 05-29-2008 06:20 AM
that sounds accurate. i need to remove the door panels or just inspect the window frame? i dont recall seeing anything wrong with the actual window frame...at least, i know there is no material missing that is visible
javadog 05-29-2008 06:32 AM
Just look at the window frame first, the part above the door shell. Compare the left and right sides, to see if they look different. Wiggle the glass with your hands a little bit. If you can't find any problems, pull the door panel and make sure everything is still properly attached inside the door.
JR
ramonesfreak 05-29-2008 06:36 AM
ok. thanks. ill look closely after work. i suspect ill just leave it alone. usually the window is either all the way down or all the way up and doestn rattle...im just being picky i guess
deshetlr 05-29-2008 09:34 AM
I had the problem on the driver side. I fond a thread that iscussed all the possibilities. One was a simple adjustment of the mechanizm. There are to bolt heads about 2 inches apart n the middle of the door panel removed). I made very slight ajustments to them and tested fo rattle. It was gone and has not eturned. Wish I could be mor technical but you may want to look at a manual or find hat thread.
Good luck.
