Clutch problems after engine swap
I swaped the engine in my 72 911 this weekend.
I took out the original 2.4MFI and mounted the fresh rebuildt 3.0 CIS. The clutch does not work. It just bounses when it is depressed. I feel restistance in the pedal, but the clutch does not disengage.. |
Did you forget to engage the release fork into the TO bearing when you joined the engine to the tranny?
| All times are GMT -8. The time now is 09:35 AM. |
